gistfile1.txt
{"reqId":"0PuWCz3YUrZN92wXXzlW","remoteAddr":"146.227.0.33","app":"files_versions","message":"Expire: \/EDI-NET\/EDI-NET\/Work Packages\/WP4 Training material preparation\/2-SETUP\/archive\/SETUP_Manual_Dashboard_20170624.docx.v1493395703","level":0,"time":"2017-07-11T08:26:34+00:00","method":"GET","url":"\/cron.php","user":"--"}
{"reqId":"iwPMFqL7q28EkBKM0Og0","remoteAddr":"146.227.0.33","app":"no app in context","message":"Current user is not logged in","level":0,"time":"2017-07-11T08:56:04+00:00","method":"GET","url":"\/index.php\/apps\/files\/?dir=%2F","user":"--"}
{"reqId":"yLF6Q+EJ88Jh54NsgOII","remoteAddr":"146.227.159.62","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 404 File with name Power\\\/Work Packages\\\/M18 Review\\\/Other could not be located\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\NotFound\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(903): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\ObjectTree->getNodeForPath('Power\\\/Work Pack...')\\n#1 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(334): Sabre\\\\DAV\\\\Server->getPropertiesForPath('Power\\\/Work Pack...', Array, 1)\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPropFind(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PROPFIND', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(138): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/objecttree.php\",\"Line\":168,\"User\":\"jriley\"}","level":0,"time":"2017-07-11T09:42:07+00:00","method":"PROPFIND","url":"\/remote.php\/webdav\/Power\/Work%20Packages\/M18%20Review\/Other","user":"jriley"}
{"reqId":"SZTgXzEt6Q2XSzm1vSTU","remoteAddr":"80.153.230.3","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 409 Parent node does not exist\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\Conflict\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(588): Sabre\\\\DAV\\\\Server->createCollection('Power\\\/Work Pack...', Object(Sabre\\\\DAV\\\\MkCol))\\n#1 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpMkcol(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#2 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#3 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:MKCOL', Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#6 \\\/var\\\/www\\\/owncloud\\\/remote.php(138): require_once('\\\/var\\\/www\\\/ownclo...')\\n#7 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php\",\"Line\":1107,\"User\":\"mbecker\"}","level":4,"time":"2017-07-11T09:42:10+00:00","method":"MKCOL","url":"\/remote.php\/webdav\/Power\/Work%20Packages\/M18%20Review\/Deliverables","user":"mbecker"}
{"reqId":"0PmB7085bssbB+jZMWI9","remoteAddr":"80.153.230.3","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 404 File with name Power\\\/Work Packages\\\/M18 Review\\\/Attendance sheets could not be located\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\NotFound\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(178): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\ObjectTree->getNodeForPath('Power\\\/Work Pack...')\\n#1 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(285): Sabre\\\\DAV\\\\Tree->delete('Power\\\/Work Pack...')\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpDelete(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:DELETE', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(138): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/objecttree.php\",\"Line\":168,\"User\":\"mbecker\"}","level":0,"time":"2017-07-11T09:42:11+00:00","method":"DELETE","url":"\/remote.php\/webdav\/Power\/Work%20Packages\/M18%20Review\/Attendance%20sheets","user":"mbecker"}
{"reqId":"eynUJokSGToJ6d3IvbNi","remoteAddr":"80.153.230.3","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"Power\\\/Work Packages\\\/WP1 Project management and Quality Assurance\\\/M18 Review\\\/Deliverables\\\/annexes to D1.1\\\/Annex A - Deliverable template.docx\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1070): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #44)\\n#1 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(511): Sabre\\\\DAV\\\\Server->updateFile('Power\\\/Work Pack...', Resource id #44, NULL)\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(138): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/file.php\",\"Line\":174,\"User\":\"mbecker\"}","level":4,"time":"2017-07-11T09:42:18+00:00","method":"PUT","url":"\/remote.php\/webdav\/Power\/Work%20Packages\/WP1%20Project%20management%20and%20Quality%20Assurance\/M18%20Review\/Deliverables\/annexes%20to%20D1.1\/Annex%20A%20-%20Deliverable%20template.docx","user":"mbecker"}
{"reqId":"JjdzZ5QPkBJXFQg\/eGd\/","remoteAddr":"80.153.230.3","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"Power\\\/Work Packages\\\/WP1 Project management and Quality Assurance\\\/M18 Review\\\/Deliverables\\\/annexes to D1.1\\\/Annex B - Power presentation template_for project meetings.pptx\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1070): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #44)\\n#1 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(511): Sabre\\\\DAV\\\\Server->updateFile('Power\\\/Work Pack...', Resource id #44, NULL)\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(138): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/file.php\",\"Line\":174,\"User\":\"mbecker\"}","level":4,"time":"2017-07-11T09:42:18+00:00","method":"PUT","url":"\/remote.php\/webdav\/Power\/Work%20Packages\/WP1%20Project%20management%20and%20Quality%20Assurance\/M18%20Review\/Deliverables\/annexes%20to%20D1.1\/Annex%20B%20-%20Power%20presentation%20template_for%20project%20meetings.pptx","user":"mbecker"}
{"reqId":"VLY13QGrcb35YU3k+O+5","remoteAddr":"80.153.230.3","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"Power\\\/Work Packages\\\/WP1 Project management and Quality Assurance\\\/M18 Review\\\/Deliverables\\\/annexes to D1.1\\\/Annex D - Template for MoM.docx\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(179): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->delete()\\n#1 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(285): Sabre\\\\DAV\\\\Tree->delete('Power\\\/Work Pack...')\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpDelete(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:DELETE', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(138): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/file.php\",\"Line\":342,\"User\":\"mbecker\"}","level":4,"time":"2017-07-11T09:42:19+00:00","method":"DELETE","url":"\/remote.php\/webdav\/Power\/Work%20Packages\/WP1%20Project%20management%20and%20Quality%20Assurance\/M18%20Review\/Deliverables\/annexes%20to%20D1.1\/Annex%20D%20-%20Template%20for%20MoM.docx","user":"mbecker"}
{"reqId":"V6\/B5j5WbsCIsTF3xihi","remoteAddr":"80.153.230.3","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"Power\\\/Work Packages\\\/WP1 Project management and Quality Assurance\\\/M18 Review\\\/Deliverables\\\/annexes to D1.1\\\/Annex J - QA review scheduling.docx\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(179): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->delete()\\n#1 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(285): Sabre\\\\DAV\\\\Tree->delete('Power\\\/Work Pack...')\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpDelete(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:DELETE', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(138): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/file.php\",\"Line\":342,\"User\":\"mbecker\"}","level":4,"time":"2017-07-11T09:42:23+00:00","method":"DELETE","url":"\/remote.php\/webdav\/Power\/Work%20Packages\/WP1%20Project%20management%20and%20Quality%20Assurance\/M18%20Review\/Deliverables\/annexes%20to%20D1.1\/Annex%20J%20-%20QA%20review%20scheduling.docx","user":"mbecker"}
{"reqId":"VPYBPIQ9xfYteUPuXZgY","remoteAddr":"80.153.230.3","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 423 \\\"Power\\\/Work Packages\\\/WP1 Project management and Quality Assurance\\\/M18 Review\\\/Earlier versions of Presentations\\\/!POWER_Boardmeeting_2017-06-21_CA.pptx\\\" is locked\",\"Exception\":\"OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Exception\\\\FileLocked\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(179): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->delete()\\n#1 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(285): Sabre\\\\DAV\\\\Tree->delete('Power\\\/Work Pack...')\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpDelete(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:DELETE', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(55): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(138): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/connector\\\/sabre\\\/file.php\",\"Line\":342,\"User\":\"mbecker\"}","level":4,"time":"2017-07-11T09:42:23+00:00","method":"DELETE","url":"\/remote.php\/webdav\/Power\/Work%20Packages\/WP1%20Project%20management%20and%20Quality%20Assurance\/M18%20Review\/Earlier%20versions%20of%20Presentations\/!POWER_Boardmeeting_2017-06-21_CA.pptx","user":"mbecker"}
This file has been truncated. show original
