Hi!
For some time I get error messages as you can see in the screen shot! I also get messages who tells me that there is a action needed.
I´m really clueless because I don´t know what to do!
Greez Markus
Hi!
Greez Markus
Hi Markus,
a little more info would be helpful.
Also, I don’t see any screen shot
No, I speak German too.
Can you find out the file names of the files in question? and it would be nice if you compare the file in your client folder and in the server folder. I would like to know if there are any differences.
Thank you for responding. What I did yesterday is I deleted both files. Now the problem is solved. I guess the files were not ok…
