Synchronize owncloud
Dear all,
every time when i start my Mac and Owncloud synchronizes there is an error message that one folder can not be found.
The error message in german is: Ordner XY konnte auf Grund eines Fehlers nicht synchronisiert werden.
But these folder was delet a year ago.
Do you know why this error message is displayed every time?
Thanks for your help in advance.
Hello, what is your client version ? Server version?
Hi Glannes31, I’m using the community version.
Yes, but it’s Owncloud 10.0.4 ? For client version 2.4 ?
Yes this is the version
Okay, on your owncloud server (terminal) , do an occ files:scan -all . If you have serveral users , you can do occ files:scan (your_username)
The problem is solved?
The problem is solved.
Thanks for your help!
Could you set my answer as the solution ? Thanks
