Syncronization of all files
Several files are not syncronized.
In the German version the error reports are: “Zeitüberschreitung bei der Verbindung” and “Die Datei ist in der Ignorierliste geführt.” However the last report is wrong: these files are not part of the ignore list. In fact I don’t use an ignore list. The files which are not syncronized are encrypted with the software Boxcryptor. Because of that filenames sometimes are long and files normally have names like [filename].bc. However most of the encrypted files are syncronized.
A further error is: “07.02.2019 19:59:25,[filename].bc, D:\Users\XXXX\ownCloud,Error transferring httpsowncloud/[filename].bc - server replied: (Could not write file contents)(Übersprungen aufgrund des früheren Fehler,s erneuter Versuch in 23 Stunden)”
ownCloud version: 10.0.10 (stable)
Client version: 2.5.2 (build 11181)
Operating system: Windows 10 Pro 64-bit, Version 1809 (build 17763.292)
OS language: German
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindoworowncloud --logfile log.txt
(On Windows usingcmd.exe, you might need to firstcdinto the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile ) -
Web server error log:
