Hola alguien tendrá el mismo problema adjunto la imagen. Actualice a 7.2 pero sigue sin funcionar no se si me falta considerar algunos pasos ayuda.
i think you need to update to PHP 7.2.0 or later as the message is explaining. If you have already updated to PHP 7.2.0 or later make sure that your web server is using that version and not an older like 7.0.33.
Thank you so much, i did it and work greetings.
