- I find it difficult to answer this question
The server should work without errors. The client should not “hang” in a “pending” state.
Multiple server errors:
owncloud.log:
- “message”:“token xxx does not exist”
- “message”:“Abandoning paged search - last cookie: ‘’, cookies: <>”
- “message”:“Cookie for cn=sia57 1,ou=sia57,ou=YYY,ou=ZZZ,dc=DDD,dc=CCC at 0-500 is ‘’”
crash.log: - “message”: “Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2006] MySQL server has gone away”
- “message”: “Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [1040] Too many connections”
The problem lies in the fact that the client, for unknown reasons, stops synchronizing files and hangs in the “pending” state.
The statistics are such that 20-30 clients out of 400 “freeze” per day.
And they require manual intervention.
Ubuntu 20.04.1 LTS
Linux drive 5.4.0-64-generic #72-Ubuntu SMP Fri Jan 15 10:27:54 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
nginx/1.19.6
10.3.25-MariaDB-0ubuntu0.20.04.1
PHP 7.4.3
10.5.0.10
Updated from 10.0.6 after problems with clients of versions 2.7.x
“config”: {
“updatechecker”: false,
“instanceid”: “oc04ujnl5w5l”,
“trusted_domains”: [
“drive.domain.name”,
“cloud.domain.name”
“datadirectory”: “/storage”,
“overwrite.cli.url”: “https://drive.domain.name/owncloud”,
“dbtype”: “mysql”,
“version”: “10.5.0.10”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“ldapIgnoreNamingRules”: false,
“loglevel”: 0,
“maintenance”: false,
“appstore.experimental.enabled”: true,
“memcache.distributed”: “\OC\Memcache\Redis”,
“memcache.locking”: “\OC\Memcache\Redis”,
“memcache.local”: “\OC\Memcache\APCu”,
“redis”: {
“host”: “/var/run/redis/redis.sock”,
“port”: 0
“trashbin_retention_obligation”: “1, 3”,
“versions_retention_obligation”: “1, 3”
Enabled:
- comments: 0.3.0
- configreport: 0.2.0
- dav: 0.6.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_sharing: 0.13.0
- files_texteditor: 2.3.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- gallery: 16.1.1
- market: 0.6.0
- notifications: 0.5.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
- updatenotification: 0.2.1
- user_ldap: 0.15.2
Disabled: - activity
- audioplayer
- calendar
- documents
- encryption
- external
- files_antivirus
- files_mediaviewer
- files_pdfviewer
- user_external
- xmas
no
Are you using an external user-backend, if yes which one:
LDAP
| Configuration | s01 |
| hasMemberOfFilterSupport | 1 |
| hasPagedResultSupport | |
| homeFolderNamingRule | attr:sAMAccountName |
| lastJpegPhotoLookup | 0 |
| ldapAgentName | CN=Cloud,OU=Admins,DC=domain,DC=name |
| ldapAgentPassword | *** |
| ldapAttributesForGroupSearch | |
| ldapAttributesForUserSearch | |
| ldapBackupHost | |
| ldapBackupPort | |
| ldapBase | DC=domain,DC=name |
| ldapBaseGroups | DC=domain,DC=name |
| ldapBaseUsers | DC=domain,DC=name |
| ldapCacheTTL | 600 |
| ldapConfigurationActive | 1 |
| ldapDynamicGroupMemberURL | |
| ldapEmailAttribute | |
| ldapExperiencedAdmin | 0 |
| ldapExpertUUIDGroupAttr | |
| ldapExpertUUIDUserAttr | objectguid |
| ldapExpertUsernameAttr | |
| ldapGroupDisplayName | cn |
| ldapGroupFilter | (&(|(objectclass=group))(|(cn=Marketyng)(cn=Domain Admins)(cn=Domain Users))) |
| ldapGroupFilterGroups | Marketyng;Domain Admins;Domain Users |
| ldapGroupFilterMode | 0 |
| ldapGroupFilterObjectclass | group |
| ldapGroupMemberAssocAttr | member |
| ldapHost | domain.name |
| ldapIgnoreNamingRules | |
| ldapLoginFilter | (&(&(|(objectclass=person))(|(|(memberof=CN=Domain Admins,CN=Users,DC=domain,DC=name)(primaryGroupID=512))(|(memberof=CN=Domain Users,CN=Users,DC=domain,DC=name)(primaryGroupID=513))))(|(samaccountname=%uid)(|(mailPrimaryAddress=%uid)(mail=%uid))(|(cn=%uid)(userPrincipalName=%uid)))) |
| ldapLoginFilterAttributes | cn;userPrincipalName |
| ldapLoginFilterEmail | 1 |
| ldapLoginFilterMode | 0 |
| ldapLoginFilterUsername | 1 |
| ldapNestedGroups | 0 |
| ldapNetworkTimeout | 2 |
| ldapOverrideMainServer | |
| ldapPagingSize | 500 |
| ldapPort | 3268 |
| ldapQuotaAttribute | |
| ldapQuotaDefault | |
| ldapTLS | 0 |
| ldapUserDisplayName | displayName |
| ldapUserDisplayName2 | |
| ldapUserFilter | (&(|(objectclass=person))(|(|(memberof=CN=Domain Admins,CN=Users,DC=domain,DC=name)(primaryGroupID=512))(|(memberof=CN=Domain Users,CN=Users,DC=domain,DC=name)(primaryGroupID=513)))) |
| ldapUserFilterGroups | Domain Admins;Domain Users |
| ldapUserFilterMode | 0 |
| ldapUserFilterObjectclass | person |
| ldapUserName | samaccountname |
| ldapUuidGroupAttribute | auto |
| ldapUuidUserAttribute | auto |
| turnOffCertCheck | 0 |
| useMemberOfToDetectMembership | 1 |
Win 7 x64 Pro
2021/02/09 13:30:11 [error] 825#825: *117783 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2006] MySQL server has gone away in /var/www/owncloud/lib/private/DB/Connection.php:62
2021/02/09 12:00:11 [error] 825#825: *1292 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [1040] Too many connections in /var/www/owncloud/lib/private/DB/Connection.php:62
{“reqId”:“25adb674-2f7e-4dc2-95cb-0539ff31777e”,“level”:0,“time”:“2021-02-09T11:18:57+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“3D275483-8D61-45A7-A2EC-22AC641F7966”,“app”:“user_ldap”,“method”:“PROPFIND”,“url”:"/remote.php/dav/files/3D275483-8D61-45A7-A2EC-22AC641F7966/",“message”:“Abandoning paged search - last cookie: ‘’, cookies: <>”}
{“reqId”:“25adb674-2f7e-4dc2-95cb-0539ff31777e”,“level”:0,“time”:“2021-02-09T11:18:57+00:00”,“remoteAddr”:“xxx.xxx.xxx.xxx”,“user”:“3D275483-8D61-45A7-A2EC-22AC641F7966”,“app”:“OC\Authentication\Token\DefaultTokenProvider::getToken”,“method”:“PROPFIND”,“url”:"/remote.php/dav/files/3D275483-8D61-45A7-A2EC-22AC641F7966/",“message”:“token eb07214213771d11b5ad483781e5626060ba0373ab975aebd3a13a18fd3e46f0851d974dbb04903b84e31982929f927fe84643881ee774292e8baabedbf7ddf6 does not exist”}
there are no problems in the browser
