I installed the ownCloud Appliance in a fresh install of Ubuntu 18.04 server on a Virtual Box. The install runs smoothly and as expected. I received the license in an email. I downloaded the license doc. I opened the browser. I typed in the given local IP. I get the http://10.0.0.23/univention/portal/. The Univention login returns " The connection to the Univention Management Console Server broke up unexpectedly". And the ownCloud login returns an error. I clicked the request for a new password via email. I never get an email.
- Installed the Appliance on virtual box.
- Followed the instructions. Obtained the license and saved it in my download folder. Opened the browser to the specified ip. Uploaded the license doc successfully. I found the next screen http:// 10.0.0.23/ univention/ portal/
- Input the username “Administrator” and the chosen password. When that failed, I tried my email and password. That also failed. I tried the request for a link to a new password. I have not got an email. Yes, I checked the spam and junk folders. Yes, the email is working both send and receive to other accounts.
Open the owncloud.
I get an error saying my user name and or password is incorrect. Then I click on the send me a new password link. I don’t get an email.
Server configuration Virtual Box is a fresh install of Ubuntu Server 18.04 The desktop is running Ubuntu 16.04
Database: is auto installed with the ownCloud Appliance for Virtual Box
**PHP version:*is also auto installed with the ownCloud Appliance for Virtual Box *
**ownCloud version:Appliance production 10.0.3 2017/09/15
**Updated from an older ownCloud or fresh install:no
**Where did you install ownCloud from:Download Server Packages - ownCloud
Can't login.
Yes, an external hard drive plugged into the router, but it's not in any way connected to the Virtual Box installation.
Yes, On the desktop, the boot install needs the encryption password prior to main boot and login password. Again, should have no effect on the Virtual Box or the ownCloud appliance.
No
Could not open input file: occ
**Browser:firefox and google chrome
Ubuntu 16.04 lts
