Docker Host doesn’t have public IP Address. In order Collabora Code can be accesed from internet, I create iptables DNAT in other host (host X).
I don’t use reverse proxy.
Problem
When I use private IP address of Docker Host in Collabora Online setting in owncloud, I can use Collabora to edit file and etc. The problem is coming when i use Public IP Address of host X in Collabora Online setting in owncloud. I get error:
The requested URL /index.php/apps/richdocuments/WOPISrc=Give yourself a better website » MY DOMAIN Document.docx&lang=en&closebutton=1&revisionhistory=1&permission=readonly was not found on this server.
Is this the full error message or have you redacted your private/public IP?
I would assume that something with the redirection / name resolution does not work.
If you have ownCloud in a docker container and collabora in a docker container, maybe you need to edit your etc/hosts file for the name resolution to work.
My owncloud is running in different vm, not in docker. The full error that I got only the error that I posted above. There is no error that i found in collabora container & owncloud logs.
I integrate Collabora Code to OwnCloud using apps richdocument.
Yes, I edited manually /etc/hosts/ in Collabora Container. If I use local IP Address in /etc/hosts:
and in Collabora Setting in owncloud I use local IP address of Docker Host, Collabora is working well with OwnCloud. I can edit document and etc.
But if I use Public IP in Collabora Setting in owncloud and I also change /etc/hosts with public IP Address, Collabora Code is not working and I am getting the error above.
I don’t know why. Using local IP address is working well, but not for public IP Address.
