The server didn't work again (Failed to load panel.....) operation of deleting and uploading wererejected, not include downloading (Final test after some attempts)
It was fine to Sync my files before I went out. Then I had been in lirary and added a note in a file. I rebooted mypi by ssh.
1.And I synchronized it to my laptop after I got home.
2.It showed Sync failed. I Relinked account. and it showed conflict .
3.Though I deleted that note ,there was a difference of 1 bit. So I download that file and replaced my local’s
All fixed
The Not Synced still showed that file’s in “Blacklisted” and some operations were rejected but still in Browse
Operating system:Raspberry4B Bookworm
Web server: Nginx
Database: Mysql
PHP version: PHP 7.4
ownCloud version: (see ownCloud admin page) 10.13.0
Updated from an older ownCloud or fresh install: i don’t remem’
Where did you install ownCloud from: wget official
"reqId":"24cimlVovNs8J7w7ApXO","level":3,"time":"2023-11-22T15:17:47+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"PHP","method":"POST","url":"\/apps\/carnet\/note\/saveText","message":"fclose(): supplied resource is not a valid stream resource at \/var\/www\/owncloud\/apps-external\/carnet\/lib\/Controller\/NoteController.php#981"}
{"reqId":"47ba926d-da83-4b23-8256-0c62655b7263","level":3,"time":"2023-11-24T11:43:24+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"PHP","method":"PUT","url":"\/remote.php\/dav\/files\/Raid_ope\/%20Note\/100-Computer%20knowledge\/Linux\/Linux%E7%9F%A5%E8%AF%86.md","message":"fopen(\/media\/ownclouddrive\/data\/Raid_ope\/files\/Note\/100-Computer knowledge\/Linux\/Linux\u77e5\u8bc6.md.ocTransferId1088178279.part): failed to open stream: Permission denied at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#298"}
{"reqId":"47ba926d-da83-4b23-8256-0c62655b7263","level":3,"time":"2023-11-24T11:43:24+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"webdav","method":"PUT","url":"\/remote.php\/dav\/files\/Raid_ope\/%20Note\/100-Computer%20knowledge\/Linux\/Linux%E7%9F%A5%E8%AF%86.md","message":"\\OC\\Files\\Filesystem::fopen() failed"}
{"reqId":"47ba926d-da83-4b23-8256-0c62655b7263","level":4,"time":"2023-11-24T11:43:24+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"webdav","method":"PUT","url":"\/remote.php\/dav\/files\/Raid_ope\/%20Note\/100-Computer%20knowledge\/Linux\/Linux%E7%9F%A5%E8%AF%86.md","message":"Exception: HTTP\/1.1 500 Could not write file contents: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\",\"Message\":\"Could not write file contents\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1137): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put()\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(492): Sabre\\\\DAV\\\\Server->updateFile()\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(89): Sabre\\\\DAV\\\\CorePlugin->httpPut()\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(472): Sabre\\\\DAV\\\\Server->emit()\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(253): Sabre\\\\DAV\\\\Server->invokeMethod()\\n#5 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(348): Sabre\\\\DAV\\\\Server->start()\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":203}"}
{"reqId":"adda30bd-6bcb-48c5-9bc5-2771f444b0cc","level":3,"time":"2023-11-24T11:43:55+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"PHP","method":"PUT","url":"\/remote.php\/dav\/files\/Raid_ope\/%20Note\/100-Computer%20knowledge\/Linux\/Linux%E7%9F%A5%E8%AF%86.md","message":"fopen(\/media\/ownclouddrive\/data\/Raid_ope\/files\/Note\/100-Computer knowledge\/Linux\/Linux\u77e5\u8bc6.md.ocTransferId1233461876.part): failed to open stream: Permission denied at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#298"}
{"reqId":"adda30bd-6bcb-48c5-9bc5-2771f444b0cc","level":3,"time":"2023-11-24T11:43:55+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"webdav","method":"PUT","url":"\/remote.php\/dav\/files\/Raid_ope\/%20Note\/100-Computer%20knowledge\/Linux\/Linux%E7%9F%A5%E8%AF%86.md","message":"\\OC\\Files\\Filesystem::fopen() failed"}
{"reqId":"adda30bd-6bcb-48c5-9bc5-2771f444b0cc","level":4,"time":"2023-11-24T11:43:55+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"webdav","method":"PUT","url":"\/remote.php\/dav\/files\/Raid_ope\/%20Note\/100-Computer%20knowledge\/Linux\/Linux%E7%9F%A5%E8%AF%86.md","message":"Exception: HTTP\/1.1 500 Could not write file contents: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\",\"Message\":\"Could not write file contents\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1137): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put()\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(492): Sabre\\\\DAV\\\\Server->updateFile()\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(89): Sabre\\\\DAV\\\\CorePlugin->httpPut()\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(472): Sabre\\\\DAV\\\\Server->emit()\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(253): Sabre\\\\DAV\\\\Server->invokeMethod()\\n#5 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(348): Sabre\\\\DAV\\\\Server->start()\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":203}"}
{"reqId":"53feff2c-483a-42e6-9f25-465e2f069e3c","level":3,"time":"2023-11-24T11:53:12+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"PHP","method":"PUT","url":"\/remote.php\/dav\/files\/Raid_ope\/%20Note\/100-Computer%20knowledge\/Linux\/Linux%E7%9F%A5%E8%AF%86.md","message":"fopen(\/media\/ownclouddrive\/data\/Raid_ope\/files\/Note\/100-Computer knowledge\/Linux\/Linux\u77e5\u8bc6.md.ocTransferId314349151.part): failed to open stream: Permission denied at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#298"}
{"reqId":"53feff2c-483a-42e6-9f25-465e2f069e3c","level":3,"time":"2023-11-24T11:53:12+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"webdav","method":"PUT","url":"\/remote.php\/dav\/files\/Raid_ope\/%20Note\/100-Computer%20knowledge\/Linux\/Linux%E7%9F%A5%E8%AF%86.md","message":"\\OC\\Files\\Filesystem::fopen() failed"}
{"reqId":"53feff2c-483a-42e6-9f25-465e2f069e3c","level":4,"time":"2023-11-24T11:53:12+
00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/Raid_ope\/%20Note\/100-Computer%20knowledge\/Linux\/vim.md?c=915030c6c90f9352b54935790367be3d&x=64&y=64&forceIcon=0&preview=1","message":"fopen(\/media\/ownclouddrive\/data\/Raid_ope\/thumbnails\/283\/2048-2048-max.png): failed to open stream: Permission denied at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#298"}
{"reqId":"uc7wnfmHeFhiC3za8ZJp","level":3,"time":"2023-11-24T11:54:38+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"PHP","method":"GET","url":"\/remote.php\/dav\/files\/Raid_ope\/%20Note\/100-Computer%20knowledge\/Linux\/vim.md?c=915030c6c90f9352b54935790367be3d&x=64&y=64&forceIcon=0&preview=1","message":"fopen(\/media\/ownclouddrive\/data\/Raid_ope\/thumbnails\/283\/64-64.png): failed to open stream: Permission denied at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#298"}
{"reqId":"XQDONuEovxoM5hXMIlQ8","level":3,"time":"2023-11-24T11:57:29+
When I tested to delete
00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"PHP","method":"DELETE","url":"\/remote.php\/dav\/files\/Raid_ope\/Data\/23%E6%B3%A8%E4%BC%9A%E6%A4%B0%E5%AD%90-%E7%A8%8E%E6%B3%95%20%E4%B8%8A%E4%B8%8B-OCR.pdf","message":"unlink(\/media\/ownclouddrive\/data\/Raid_ope\/files\/Data\/23\u6ce8\u4f1a\u6930\u5b50-\u7a0e\u6cd5 \u4e0a\u4e0b-OCR.pdf): Operation not permitted at \/var\/www\/owncloud\/lib\/private\/Files\/Storage\/Local.php#238"}
{"reqId":"PCJ2hyppgklE4nLp3aqF","level":3,"time":"2023-11-24T12:50:22+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"no app in context","method":"GET","url":"\/index.php\/settings\/admin","message":"Failed to load panel: OCA\\Carnet\\Settings\\AdminSettings with error: Could not resolve OCA\\Carnet\\Settings\\AdminSettings! Class OCA\\Carnet\\Settings\\AdminSettings does not exist"}
When I tried upload
00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"webdav","method":"PUT","url":"\/remote.php\/dav\/files\/Raid_ope\/8181-clown-makeup.gif","message":"Exception: HTTP\/1.1 500 Could not write file contents: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\",\"Message\":\"Could not write file contents\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(172): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put()\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1098): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile()\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(504): Sabre\\\\DAV\\\\Server->createFile()\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(89): Sabre\\\\DAV\\\\CorePlugin->httpPut()\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(472): Sabre\\\\DAV\\\\Server->emit()\\n#5 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(253): Sabre\\\\DAV\\\\Server->invokeMethod()\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(348): Sabre\\\\DAV\\\\Server->start()\\n#7 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#8 \\\/var\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/ownclo...')\\n#9 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":203}"}
{"reqId":"BCigZW9C3FY7AWY4NBri","level":3,"time":"2023-11-24T17:41:07+00:00","remoteAddr":"192.168.50.214","user":"Raid_ope","app":"no app in context","method":"GET","url":"\/settings\/admin","message":"Failed to load panel: OCA\\Carnet\\Settings\\AdminSettings with error: Could not resolve OCA\\Carnet\\Settings\\AdminSettings! Class OCA\\Carnet\\Settings\\AdminSettings does not exist"}
carnet
Are you using encryption: no
Browser: Chrome
Operating system: windows11
Nov 24 21:45:55 raspberrypi systemd[1]: Starting nginx.service - A high performance web server and a reverse proxy server...
Nov 24 21:45:55 raspberrypi nginx[7909]: 2023/11/24 21:45:55 [warn] 7909#7909: "ssl_stapling" ignored, issuer certificate not found for certificate "/etc/nginx/cert.pem"
Nov 24 21:45:55 raspberrypi nginx[7910]: 2023/11/24 21:45:55 [warn] 7910#7910: "ssl_stapling" ignored, issuer certificate not found for certificate "/etc/nginx/cert.pem"
Nov 24 21:45:55 raspberrypi systemd[1]: Started nginx.service - A high performance web server and a reverse proxy server.
level":3,"time":"2021-12-03T
One thing is worthy of attention. When I was in the library, I was opening
owncloud in windows, which is not in a network. It showed it’s trying to connect to the host. Whether something went wrong while it was trying to connect? Or maybe it was just a conflict led to and I replaced the file from the cloud.
i’m not sure if this third party app is still working on recent ownCloud versions because it seems that the last version for ownCloud has been releases around 4 years ago:
https://marketplace.owncloud.com/apps/carnet
I don’t think the key is carnet . I doubt that DB is. I remove all files (sudo rm -rf /var/www/owncloud) to reinstall, setting some ini fiies. It still has the problems.
My best guess is, that you messed up the access rights of the ownCloud data tree.
Maybe by the access from windows?
At the cost of time, patch server functionality. During this process, I found that Debian 12-Bookworm would automatically deleted some PHP7.4 folders, causing 502 Page. Because I deleted the database three times, I found that the PHP7.4 files were replaced by PHP8.2. This is an owncloud joke (PHP7.4 has been EOL for a year). I wanted to explain that I did not use SQL commands to mess with my data in the whole process. Should I optimize the algorithm of the windows client in the future? After all, many people have experienced the “dessert” of the client.
