Theming owncloud X
I have a owncloud installation since 8.x.
In every update I’ve make the theming with the line
‘theme’ =>‘name_theme’,
in config.php
and making a themes/name_theme folder.
Now with 10.0.3 i find a apps/theme-example where are a copy of /core and /appsinfo.
I think this was a ‘example’ to copy to the themes/ but I’ve find that now the .css and images must be there (at apps/theme-example) to work the theme.
Anyone knows why this change?
Thanks in advance.
Could be possible that this change was required to be able to publish themes at the marketplace: Marketplace
Themes are now being implemented as apps. But there is supposed to be a compatibility layer to support still the old way.
Thanks!
One more question.
How I make the own theme?
Do you know if I need make the folder theme at the apps folder?
Please have a look at our docs
https://doc.owncloud.com/server/10.0/admin_manual/enterprise/server_branding/enterprise_server_branding.html?highlight=theme
Thanks.
I don’t use the enterprise edition.
This is the correct link: ownCloud Documentation Overview
Thanks!!
The new way is quite different.
Now themes are apps and may activate like that.
A great help.
hello,
so i realize this topic is quite old … but i tried to create a theme as per link ( https://doc.owncloud.org/server/10.0/developer_manual/core/theming.html?highlight=theme ) and I get the error that the template is corrupted.
any info on this?
thanks
did you use both scripts with the right parameters?
I created both scripts and called only the theme-bootstrap.sh as instructed.
I would try doing it manually according to the documentation.
thanks @dmitry , that is what i did :slight_smile:
just a question, where ist the Slogan saved? by default installation.
did you look at the defaults.php?
just found it , like 3 Minutes ago :)) Yes, the defaults.php … slow processing on Mondays.
Thanks again and have a great day !
can i do this without sudo permissions? i have one installed in shared host
