4.0.0+0535c62b6
no Where did you install ownCloud from:
Docker The content of config/config.php:
Are you using external storage, if yes which one: local/smb/sftp/β¦
local Are you using encryption: yes/no
no Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/β¦
Can someone tell me how the config should look like to point it to a json theme file? the documentation doesnβt make much sense
Are you using the buildin IDP or an external solution like keycloak?
Also you are not being ghosted thing is, there is lots of questions popping in on several public channels we have to monitor and sometimes posts/messages get lost in the noise. We are sorry about this, we are doing our best to reply to everybody. Sometimes it might take a bit.
I am using the built in idp, is this not customizable ? I e looked through the docker container as wellβ¦
I see now in the documentation that is supposed to be an ui-folder in the idp directoryβ¦ Iβm gonna look when I get home if itβs there, although it feels like I have searched through all the folders
The internal idp has its own assets (you can recreate them by running make -C services/idp generate) in the repo. But they are not intended to modify them with the released binary at the moment. We might replace the internal IDP in the near future which may allow such things.
i still think that this topic should be closed and the discussion around theming should continue in the original Unable to theme OCIS topic. For example the users in the other topic are currently not even aware of the newly gathered info here
Thank you,
I have managed to theme my setup now, also built the idp and got it working.
I tried replacing the idp with authelia, I got everything working until the last step when it gets to the oidc callback page, it never redirects and actually logs me in.
In the logs it seems like everything is fine.
So if you guys have time, a setup example, or guide on how to get caddy and authelia to work together would be much appreciated.
