When go to the “personal settings” and scroll to “external storage”, there is no button to add one. Neither when I’m logged in as the administrator nor my normal user.
Operating system: ubuntu 16.04
Web server: apache
Database: mariaDB
PHP version: 7.0.8
ownCloud version: 9.1.2
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): no
{"reqId":"++2VJDgxmw+9iZombVcr","remoteAddr":"192.168.11.103","app":"core","message":"Could not get categories: cURL error 60: SSL certificate problem: unable to get local issuer certificate","level":3,"time":"2016-11-22T22:34:02+00:00","method":"GET","url":"\/owncloud\/index.php\/settings\/apps\/list?category=disabled&includeUpdateInfo=0","user":"admin"}
{"reqId":"ESDu+YgZlfvcgVN\/rHJa","remoteAddr":"192.168.11.103","app":"core","message":"Could not get categories: cURL error 60: SSL certificate problem: unable to get local issuer certificate","level":3,"time":"2016-11-22T22:34:02+00:00","method":"GET","url":"\/owncloud\/index.php\/settings\/apps\/categories","user":"admin"}
{"reqId":"Ymvqigmn0h4E+NAkZxTl","remoteAddr":"192.168.11.103","app":"core","message":"Could not get categories: cURL error 60: SSL certificate problem: unable to get local issuer certificate","level":3,"time":"2016-11-22T22:34:02+00:00","method":"GET","url":"\/owncloud\/index.php\/settings\/apps\/list?category=disabled&includeUpdateInfo=1","user":"admin"}
{"reqId":"Ymvqigmn0h4E+NAkZxTl","remoteAddr":"192.168.11.103","app":"core","message":"Could not get application: cURL error 60: SSL certificate problem: unable to get local issuer certificate","level":3,"time":"2016-11-22T22:34:03+00:00","method":"GET","url":"\/owncloud\/index.php\/settings\/apps\/list?category=disabled&includeUpdateInfo=1","user":"admin"}
{"reqId":"Ymvqigmn0h4E+NAkZxTl","remoteAddr":"192.168.11.103","app":"core","message":"Could not get application: cURL error 60: SSL certificate problem: unable to get local issuer certificate","level":3,"time":"2016-11-22T22:34:04+00:00","method":"GET","url":"\/owncloud\/index.php\/settings\/apps\/list?category=disabled&includeUpdateInfo=1","user":"admin"}
{"reqId":"OWN12l0qDEfN0zri6rl6","remoteAddr":"129.217.93.73","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 400 expected filesize 105035 got 0\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1070): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #72)\\n#1 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(511): Sabre\\\\DAV\\\\Server->updateFile('Documents\\\/Uni\\\/7...', Resource id #72, NULL)\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#5 \\\/var\\\/www\\\/owncloud\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(56): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/owncloud\\\/remote.php(164): require_once('\\\/var\\\/www\\\/ownclo...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":149,\"User\":\"marius
Integrity status for oC9+
