Google was no help with this. I get this error on sync one folder. There is no clue why this happens right now. Nothing changed. I have only added more files to the folder. The same happens with other clients too. I have tried to raise settings in nginx.
client_header_buffer_size
large_client_header_buffers
http2_max_header_size
http2_max_field_size
Server Error (owncloud old install allways up to date 10.0.9.5):
19568#19568: *5571 client sent header field with too long length value while processing HTTP/2 connection
Owncloud Client (Linux error: Connection timed out
**Operating system: Gentoo Stable
**Web server: Nginx 1.15.2-r1
**Database:Mariadb
**PHP version:7.1
**OwnCloud version:10.0.9.5 old install allways updated update channel Production
**Where did you install ownCloud from: owncloud.org
occ config:list system
“system”: {
“memcache.local”: “\OC\Memcache\APCu”,
“instanceid”: “ocb4eef0f5ee”,
“trusted_domains”: [
“wolke.info”
“datadirectory”: “/srv/hps/oc/wolke/owncloud/data”,
“dbtype”: “mysql”,
“version”: “10.0.9.5”,
“dbname”: “dgsf_wolke”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“installed”: true,
“forcessl”: true,
“mail_smtpmode”: “smtp”,
“preview_libreoffice_path”: “/usr/bin/soffice”,
“theme”: “”,
“maintenance”: false,
“loglevel”: 2,
“trashbin_retention_obligation”: “auto”,
“mysql.utf8mb4”: true
occ app:list
Enabled:
- activity: 2.3.7
- calendar: 1.5.7
- comments: 0.3.0
- configreport: 0.1.1
- contacts: 1.5.4
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_pdfviewer: 0.9.0
- files_sharing: 0.10.1
- files_texteditor: 2.2.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- gallery: 16.1.0
- market: 0.2.5
- notifications: 0.3.4
- phonetrack: 0.2.8
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.3.1
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- files_antivirus
- theme-example
- user_external
