Hi
Thanks for already many years one of the best Owncloud app without problems at all.
Not a big problem but annoying:
- Owncloud Tasks sync with iOS Reminder (working without problems for many years)
- Owncloud 9.1 + Tasks 0.9.3 + iOS 9.3.5 + OS X El Capitan 10.11.6
- Old and new tasks have weird invisible, when clicked visible, [OBJ] object in title
Tasks title has not to have some invisible [OBJ] object in title.
Tasks title has some invisible [OBJ] object in title, they become visible when title is clicked.
The amount of [OBJ] objects in title is always different.
See screenshot, in this task title there are 5 in front of the title.
Operating system: Debian Linux
Web server: ?
PHP version: 7
ownCloud version: 9.1
Tasks version: 0.9.3
**Updated from an older ownCloud or fresh install: update
Signing status (ownCloud 9.0 and above): ?
paste the results here.
List of activated apps: Tasks and Calendar
Insert your config.php content here
(Without the database password, passwordsalt and secret)
Are you using encryption: no
Are you using an external user-backend, if yes which one: WebDav Owncloud Client
Browser: Safari
Operating system: Mac OS X El Capitan
CalDAV-clients: Reminder
