To many active sessions
old sessions seem not to die even after login out
Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/11.1.2 Safari/605.1.15 41 minutes ago
Mozilla/5.0 (Macintosh) mirall/2.4.3 (build 10347) 41 minutes ago
i have to delete them manually .
This might be relevant:
You need to check if your background process manager ( cron) is running correctly.
Also might be a good idea to use the search function of this forum, because this forum is after all a for the users by the users forum.
i did search but didint find solution. all i read was to expensive to implement such cleaning functionality .
cron appears to run correctly
how do you know? Did you check you owncloud.log file?
yes
Sep 17 07:00:01 vorman CRON[23013]: (www-data) CMD (/usr/bin/php -f /var/www/html/owncloud/cron.php)
also under general says ran 41 minutes ago
hmm, you are right, need to investigate this.
Could you open a ticket at GitHub?
one thnig i just notice is every time i hit refresh a new session is started
Any update on this sessions from months still here
i would expect any updates in the reported issue/bugreport rather then here.
I believe this is solve now. Active sessions restricted to 1 day
