Token not found
I messed up with my db on the server and after a restore I cannot sync with the Desktop client anymore. I get an Error 500, Log says “token xxx does not exist”. I already tried to clear the oc_authtoken table in hope everything would be created fresh, no success.
Change the password, logout an login again and even remove the account and setup again does also not help…
Please fill out this template.
This is a dublicate of Token not found
closing this.
