Too many Redirects Issue
  1. Happens when I attempt login to my server.
Should have accepted my user creation and went to the next step.
I get an error saying the page redirected too many times.
ERR_TOO_MANY_REDIRECTS
I went through the following guide and got the end where you login to the server and create the user. As I input all the values I wanted for my user, and clicked Finish, thats when I started getting this error, and each time I attempt to reach the page.
Debian
nginx
Latest version
Fresh
Hey, maybe you can find some information and/or a working nginx config in the ownCloud documentation?
https://doc.owncloud.org/server/latest/admin_manual/installation/nginx_configuration.html?highlight=nginx
