TOTP 2FA doesn't seem to work with OwnCloud Server 10.15 docker container
I have managed to successfully setup a docker-compose.yml containing owncloud/server:10.15, Traefik, MariaDB and Redis containers and using my SSL certifcate succesffuly.
I can access ownCloud login page and login as the admin user and set allthe various options I want.
Everything is working well except when it comes to enabled 2FA. I enabled apps for Password Policy, OAuth2. These both work, as it correctly applies password settings I have selected and also using a desktop client makes use of OAuth2.0 correctly.
When I go to the security tab and enable forced 2FA for all users. I then create a new user, the email arrives, I follow th elink and was expecting the login page to have a QR code and work like shown in the documentation but it does not. It only has the usual login option with username and password.
I read that it requires imagemagick and php-imagick when I interrogate the docker container I can see that it apepars to have these present inside the container.
Note that I can reproduce the issue if I use the simpler example docker compose setup from ownCloud’s documentation on the web.
Any help would be much appreciated.
  1. Create a running instance of ownCloud using: Installing with Docker :: Documentation for ownCloud (A Kiteworks Company)
  2. Login as the admin account, enable enforced 2FA for all users
  3. Create a new user and let it email them the link to setup their account.
  4. Follow the link fro mth eemail and the user sees normal login screen not a 2FA login screen.
Expect to see 2FA based login screen like show here: User Two-Factor Authentication :: Documentation for ownCloud (A Kiteworks Company)
See the normal log in screen requireing user name and password.
Ubuntu 20.04 (Ithink from ownCloud docker container)
Maria DB 11.6
From docker container seems to be 7.4.3
10.15
Fresh setup using docker compose
Official ownCloud docker hub images.
Anyone got any ideas about this?
Still stuck with it, everything else is working but I see no way to activate 2FA for users with the docker based setup.
I saw other people say it is related to ImageMagick but when I accessed the container and ran a console inside it, it appears that it has ImageMagick package installed.
You need to have a 2FA app installed, otherwise enforcing it won’t do anything because there is no app to delegate to.
The recommended 2FA app is twofactor_totp , specially if you want to enforce 2FA because it’s prepared for it. Other apps might not be prepared and might have problems with the enforcement.
If it’s a new installation, you can try other 2FA apps and check how they behave when 2FA is enforced.
Thanks for the reply.
As I’m a bit new to this, how do I install that within the docker based version of ownCloud?
When I log in as the ownCloud admin account in a browser and look at what apps I can install I do not see that application available, even when I check the box to show disabled apps.
You should have the “market” app installed and enabled (top left icon). From the “market” app, you can find and install the app you want. Note that the apps will be downloaded from https://marketplace.owncloud.com so you must have internet access.
Also note that some apps will require a license, so you should double-check that. In particular, the app I’ve proposed it’s free so you can install the app without worries.
From the settings page you can only enable or disable the apps you already have installed. The 2FA app isn’t part of the default bundle, that’s why it isn’t shown in the settings page.
Great thanks for the details. I’ll give that a try now.
That worked thanks for the help.
