TOTP always shows 'not verified'
  1. Install app ( 2-Factor Authentication app | ownCloud Marketplace
  2. Scan QR Code
  3. Insert verification code (tried using google Authenticator and FreeOTP)
  4. ‘Not verified’
TOTP should be verified
Not verified (even if I try multiple times using Authenticator & FreeOTP on all different users)
Operating system: Oracle Linux 8.4
Database: 10.3.27-MariaDB
PHP version: PHP 7.4.6
ownCloud version: (see ownCloud admin page) ownCloud 10.9.1 (stable)
Where did you install ownCloud from: Download Server Packages - ownCloud
Are you using external storage, if yes which one: nfs
Are you using encryption: no
Browser: Edge 101.0.1210.39 (Official build)
Operating system: Windows Version 10.0.19042 Build 19042
[Thu May 12 14:28:43.878629 2022] [mpm_event:notice] [pid 1583990:tid 139666520512832] AH00489: Apache/2.4.37 (Oracle Linux) configured -- resuming normal operations
[Thu May 12 14:28:43.878678 2022] [core:notice] [pid 1583990:tid 139666520512832] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Thu May 12 14:31:17.986764 2022] [mpm_event:notice] [pid 1583990:tid 139666520512832] AH00492: caught SIGWINCH, shutting down gracefully
[Thu May 12 14:32:00.440065 2022] [core:notice] [pid 1584457:tid 140527843670336] SELinux policy enabled; httpd running as context system_u:system_r:httpd_t:s0
[Thu May 12 14:32:00.441966 2022] [suexec:notice] [pid 1584457:tid 140527843670336] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using fe80::a00:27ff:fe94:4821. Set the 'ServerName' directive globally to suppress this message
[Thu May 12 14:32:00.481378 2022] [lbmethod_heartbeat:notice] [pid 1584457:tid 140527843670336] AH02282: No slotmem from mod_heartmonitor
[Thu May 12 14:32:00.483028 2022] [http2:warn] [pid 1584457:tid 140527843670336] AH02951: mod_ssl does not seem to be enabled
[Thu May 12 14:32:00.489037 2022] [mpm_event:notice] [pid 1584457:tid 140527843670336] AH00489: Apache/2.4.37 (Oracle Linux) configured -- resuming normal operations
[Thu May 12 14:32:00.489104 2022] [core:notice] [pid 1584457:tid 140527843670336] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
jquery-migrate.min.js?v=843b0499ae125a84ca945b3adef4d2d9:2 JQMIGRATE: Migrate is installed, version 1.4.0
We don’t recommend running fpm with ownCloud.
what web server are you running?
I’m using Apache 2.4.37
Maybe this might help:
I’ve never scanned the dot matrix code, always transferred the secret manually. To verify your issue, I tried scanning with my app (bitwarden). At the first try, it didn’t work, same as you wrote. But after I saved the inserted URL in the app, the authentication code is verified as expected.
I’m not a premium member of bitwarden, so I can’t use their TOTP feature, any other suggestion?
Could datetime be the culprit since my server are not synced by ntp (it’s not connected to the internet)?
Whoops, turns out it was a problem with datetime. After I fix the time to match current time it works fine and it’s verified now. Thank you for the help @alfredb @dmitry.
