Where did you install ownCloud from: gentoo repository
Everything works as long as I don’t try to use redis, either for caching or file locking. APCu seems to be working.
Here’s a snippet from config.php:
‘filelocking.enabled’ => ‘true’,
‘memcache.locking’ => ‘\OC\Memcache\Redis’,
‘redis’ =>
array (
‘host’ => ‘/tmp/redis.sock’,
‘port’ => 0,
I guess modules are there as redis and apcu show in php -m
User nginx belongs to redis group
I’ve edited redis.conf as follows:
unixsocket /tmp/redis.sock
unixsocketperm 700
bind 127.0.0.1
port 0
Tried with permissions 750 and 770 on the socket - no luck
Can you try using the standard redis port, I think it is 6379, obviously you’ll have to adjust both redis-server and owncloud configuration. I just want to rule out that the redis php library doesn’t have a problem with port 0.
Is your redis actually running? Have you checked with
# If you're using systemd, you can display the status of the service
systemctl status redis
# This tells you all the services listening on an IP:Port combination on your server
ss -tulpen
Perhaps there is something wrong with the redis server configuration, and the service doesn’t even start, or crashes after a few seconds/minutes.
2020/04/17 16:01:51 [error] 5342#5342: *74 FastCGI sent in stderr: “PHP message: PHP Warning: fopen(/var/www/cloud.mydomain.com/htdocs/owncloud/config/config.php): failed to open stream: Permission denied in /var/www/cloud.mydomain.com/htdocs/owncloud/lib/private/Config.php on line 239
PHP message: PHP Warning: flock() expects parameter 1 to be resource, boolean given in /var/www/cloud.mydomain.com/htdocs/owncloud/lib/private/Config.php on line 249
PHP message: PHP Fatal error: Uncaught Error: Call to a member function getValue() on null in /var/www/cloud.mydomain.com/htdocs/owncloud/lib/base.php:1019
Stack trace: #0 /var/www/cloud.mydomain.com/htdocs/owncloud/index.php(83): OC::crashLog(Object(Exception)) #1 {main}
thrown in /var/www/cloud.mydomain.com/htdocs/owncloud/lib/base.php on line 1020” while reading response header from upstream, client: client.ip.here, server: cloud.mydomain, request: “GET /index.php/login HTTP/2.0”, upstream: “fastcgi://127.0.0.1:9000”, host: “cloud.mydomain”
2020/04/17 16:01:52 [error] 5342#5342: *74 open() “/var/www/cloud.mydomain.com/htdocs/owncloud/favicon.ico” failed (2: No such file or directory), client: client.ip.here, server: cloud.mydomain, request: “GET /favicon.ico HTTP/2.0”, host: “cloud.mydomain”
2020/04/17 16:01:52 [info] 5342#5342: *74 client canceled stream 27 while sending request to upstream, client: client.ip.here, server: cloud.mydomain, request: “GET /favicon.ico HTTP/2.0”, upstream: “fastcgi://127.0.0.1:9000”, host: “cloud.mydomain”
2020/04/17 16:01:52 [error] 5342#5342: *74 FastCGI sent in stderr: “PHP message: PHP Warning: fopen(/var/www/cloud.mydomain.com/htdocs/owncloud/config/config.php): failed to open stream: Permission denied in /var/www/cloud.mydomain.com/htdocs/owncloud/lib/private/Config.php on line 239
PHP message: PHP Fatal error: Uncaught Exception: Could not acquire a shared lock on the config file /var/www/cloud.mydomain.com/htdocs/owncloud/config/config.php in /var/www/cloud.mydomain.com/htdocs/owncloud/lib/private/Config.php:250
Stack trace: #0 /var/www/cloud.mydomain.com/htdocs/owncloud/lib/private/Config.php(64): OC\Config->readData() #1 /var/www/cloud.mydomain.com/htdocs/owncloud/lib/base.php(135): OC\Config->__construct(’/var/www/cloud…’) #2 /var/www/cloud.mydomain.com/htdocs/owncloud/lib/base.php(523): OC::initPaths() #3 /var/www/cloud.mydomain.com/htdocs/owncloud/lib/base.php(1058): OC::init() #4 /var/www/cloud.mydomain.com/htdocs/owncloud/core/templates/404.php(7): require_once(’/var/www/cloud…’) #5 {main}
thrown in /var/www/cloud.mydomain.com/htdocs/owncloud/lib/private/Config.php on line 250” while reading response header from upstream, client: client.ip.here, server: cloud.mydomain, request: “GET /favicon.ico HTTP/2.0”, upstream: “fastcgi://127.0.0.1:9000”, host: “cloud.mydomain”
