- Two users created on ownCloud: “User1” and “User2”
- One folder shared with other users from account of user “User1” (owner of the folder shared)
- Run command: occ files:transfer-ownership --path="/Shared Folder1" User1 User2
- Gives always the error:
“In Share.php line 173:
[OCP\Files\NotFoundException]”
Folder should be moved to account of User2 (folder, subfolders, files, shares…)
After run command:
Current UCS version is 4.4-4 errata652
10.3.2-1
Fresh install
Univention (virtual Machine)
Integrity checker has been disabled. Integrity cannot be verified.
root@0fbefea02aba: /var/www/owncloud # occ config:list system
"system": {
"apps_paths": [
"url": "\/apps",
"writable": false
"path": "\/var\/www\/owncloud\/custom",
"url": "\/custom",
"writable": true
"trusted_domains": [
"localhost"
"datadirectory": "\/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/files",
"dbtype": "mysql",
"dbhost": "172.17.42.1",
"dbname": "owncloud",
"dbtableprefix": "oc_",
"log_type": "owncloud",
"supportedDatabases": [
"sqlite",
"mysql",
"pgsql"
"upgrade.disable-web": true,
"integrity.check.disabled": true,
"default_language": "en",
"overwrite.cli.url": "http:\/\/localhost\/owncloud",
"htaccess.RewriteBase": "\/owncloud",
"logfile": "\/var\/lib\/univention-appcenter\/apps\/owncloud\/data\/files\/owncloud.log",
"loglevel": 3,
"filelocking.enabled": true,
"version": "10.3.2.2",
"logtimezone": "UTC",
"installed": true,
"instanceid": "ocymhy8rqfyh",
"log_rotate_size": 104857600,
"onlyoffice": {
"verify_peer_off": true
"mail_smtpmode": "smtp",
"mail_smtpauth": 1,
"mail_smtpport": "25",
"maintenance": false,
"mysql.utf8mb4": true,
"memcache.distributed": "\\OC\\Memcache\\Redis",
"redis": {
"host": "redis",
"port": "6379"
"lost_password_link": "true",
"updatechecker": false
Enabled:
- activity: 2.5.3
- announcementcenter: 1.2.1
- brute_force_protection: 1.0.1
- comments: 0.3.0
- configreport: 0.2.0
- dav: 0.5.0
- diagnostics: 0.1.4
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.2
- files_pdfviewer: 0.11.1
- files_sharing: 0.12.0
- files_texteditor: 2.3.0
- files_textviewer: 1.0.3
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- impersonate: 0.5.0
- market: 0.5.0
- notifications: 0.5.0
- password_policy: 2.1.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
- updatenotification: 0.2.1
- user_ldap: 0.15.0
Disabled: - encryption
- external
- gallery
- onlyoffice
- richdocuments
- user_external
No
No
No
