Trash bin does not delete files - disk full
We are running a Owncloud Server 9.1.3 with external Storage. The storage is a windows server we connect over SMB/CIFS to 4 shared folders with special permissions.
We noticed that owncloud server stores the deleted files on the local drive and after a while we ran out of disk space because of that. I am speaking about following trash bin folder path (Its the SID from the user over ldap):
root@MRH-OWNCLOUD:/var/www/owncloud/data/0BF22EC2-5A60-48B4-BF2F-74C93F3375B3# du -shx ./* | sort -h
4.0K ./files
40K ./cache
1.4M ./thumbnails
9.6G ./files_versions
14G ./files_trashbin
We tried different settings in config.php for ‘trashbin_retention_obligation’ but it doesn’t delete any data in the trashbin folder. Now we have following settings:
‘trashbin_retention_obligation’ => auto,1
So it should actually delete the files in the trash bin that are older than 1 day automatically.
Can somebody help me to get this fixed?
Regards
Raphael
It should delete the the trash bin after 1 day
Does not delete any trash bin or file history folder
Ubuntu 16.10
apache2
mysql 9.1.3.1
Hello? Looks for me nobody knows an answer?
There are some steps to check first, like what the cron jobs look like, etc. seems like that one is not running: Trash bin auto deletion broken · Issue #22537 · owncloud/core · GitHub
For your users: Honestly you will need some more space here, 1 day trashbin is not sufficient! Versioning does also store the files in primary storage.
That link doesn’t work for me. I guess my CronJob is running normaly and the entry for the job i also have in the database:
| class | num_entries | oldest | newest |
| OCA\Activity\BackgroundJob\EmailNotification | 1 | 1506330826 | 1506330826 |
| OCA\Activity\BackgroundJob\ExpireActivities | 1 | 1506256201 | 1506256201 |
| OCA\DAV\CardDAV\SyncJob | 1 | 1506256204 | 1506256204 |
| OCA\Federation\SyncJob | 1 | 1506258001 | 1506258001 |
| OCA\Files\BackgroundJob\CleanupFileLocks | 1 | 1506331517 | 1506331517 |
| OCA\Files\BackgroundJob\DeleteOrphanedItems | 1 | 1506329102 | 1506329102 |
| OCA\Files\BackgroundJob\ScanFiles | 1 | 1506331516 | 1506331516 |
| OCA\Files_Sharing\DeleteOrphanedSharesJob | 1 | 1506331516 | 1506331516 |
| OCA\Files_Sharing\ExpireSharesJob | 1 | 1506256205 | 1506256205 |
| OCA\Files_Trashbin\BackgroundJob\ExpireTrash | 1 | 1506330003 | 1506330003 |
| OCA\Files_Versions\BackgroundJob\ExpireVersions | 1 | 1506330003 | 1506330003 |
| OCA\UpdateNotification\Notification\BackgroundJob | 1 | 1506256201 | 1506256201 |
| OCA\User_LDAP\Jobs\CleanUp | 1 | 1506330003 | 1506330003 |
| OCA\User_LDAP\Jobs\UpdateGroups | 1 | 1506331517 | 1506331517 |
| \OC\Authentication\Token\DefaultTokenCleanupJob | 1 | 1506331517 | 1506331517 |
I can run sudo -u www-data php cron.php
But also the Trashbin will not deleted.
Any idea how to fix this problems before the server rans full again?
Debug cron Finished OCA\User_LDAP\Jobs\CleanUp job with ID 15 2017-09-25T09:30:45+00:00
