- delete a file
- go to “deleted files”
find the deleted file in the trashbin and be able to restore it
trashbin is empty (sometimes just after a few minutes); same via ftp (user/files_trashbin)
Operating system: CentOS Linux release 7.6.1810 (Core)
Web server: Apache (on Managed Cloud Service)
PHP version: 7.1.27
ownCloud version: 10.0.10.4
Where did you install ownCloud from: not sure, was before my time here
ownCloud config report:
Are you using encryption: yes
Are you using an external user-backend, if yes which one: often Webdav, but same problem in web interface
Browser: Chrome
Operating system: Windows 10 Pro
not even sure if I have access, I will ask for it, if necessary
hundreds of “Bad Signature” and “Can not decrypt”-Exceptions like this
{"reqId":"0db720ab-3a0a-4d7c-be0d-916d23f2865f","level":4,"time":"2019-03-25T06:56:29+00:00","remoteAddr":"***","user":"***","app":"webdav","method":"GET","url":"\/remote.php\/dav\/files\/***\/***\/Documents\/***.pdf","message":"Exception: Bad Signature: {\"Exception\":\"OC\\\\HintException\",\"Message\":\"Bad Signature\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/encryption\\\/lib\\\/Crypto\\\/Crypt.php(463): OCA\\\\Encryption\\\\Crypto\\\\Crypt->checkSignature('f4mRTveoNfhGalQ...', '\\\\xDBVJs\\\\n\\\\xA7\\\\tE\\\\x92\\\\x95Ii\\\\x1F-\\\\xEB...', '6018fa51d77fed8...')\\n#1 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/encryption\\\/lib\\\/Crypto\\\/Encryption.php(369): OCA\\\\Encryption\\\\Crypto\\\\Crypt->symmetricDecryptFileContent('f4mRTveoNfhGalQ...', '\\\\xDBVJs\\\\n\\\\xA7\\\\tE\\\\x92\\\\x95Ii\\\\x1F-\\\\xEB...', 'AES-256-CTR', 2, 0)\\n#2 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/lib\\\/private\\\/Files\\\/Stream\\\/Encryption.php(454): OCA\\\\Encryption\\\\Crypto\\\\Encryption->decrypt(*** sensitive parameters replaced ***)\\n#3 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/lib\\\/private\\\/Files\\\/Stream\\\/Encryption.php(289): OC\\\\Files\\\\Stream\\\\Encryption->readCache()\\n#4 [internal function]: OC\\\\Files\\\\Stream\\\\Encryption->stream_read(8192)\\n#5 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/streams\\\/src\\\/Wrapper.php(83): fread(Resource id #107, 8192)\\n#6 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/streams\\\/src\\\/CallbackWrapper.php(91): Icewind\\\\Streams\\\\Wrapper->stream_read(8192)\\n#7 [internal function]: Icewind\\\\Streams\\\\CallbackWrapper->stream_read(8192)\\n#8 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/lib\\\/composer\\\/sabre\\\/http\\\/lib\\\/Sapi.php(80): stream_copy_to_stream(Resource id #110, Resource id #112, '1127823')\\n#9 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(498): Sabre\\\\HTTP\\\\Sapi::sendResponse(Object(Sabre\\\\HTTP\\\\Response))\\n#10 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#11 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/dav\\\/lib\\\/Server.php(298): Sabre\\\\DAV\\\\Server->exec()\\n#12 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#13 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/remote.php(165): require_once('\\\/var\\\/www\\\/vhosts...')\\n#14 {main}\",\"File\":\"\\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/encryption\\\/lib\\\/Crypto\\\/Crypt.php\",\"Line\":483}"}
{"reqId":"4182f883-b21f-4837-adbe-537233b69069","level":4,"time":"2019-03-25T06:59:00+00:00","remoteAddr":"***","user":"***","app":"webdav","method":"GET","url":"\/remote.php\/dav\/files\/***\/***\/***.pdf","message":"Exception: Can not decrypt this file, probably this is a shared file. Please ask the file owner to reshare the file with you.: {\"Exception\":\"OC\\\\Encryption\\\\Exceptions\\\\DecryptionFailedException\",\"Message\":\"Can not decrypt this file, probably this is a shared file. Please ask the file owner to reshare the file with you.\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/lib\\\/private\\\/Files\\\/Stream\\\/Encryption.php(454): OCA\\\\Encryption\\\\Crypto\\\\Encryption->decrypt(*** sensitive parameters replaced ***)\\n#1 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/lib\\\/private\\\/Files\\\/Stream\\\/Encryption.php(289): OC\\\\Files\\\\Stream\\\\Encryption->readCache()\\n#2 [internal function]: OC\\\\Files\\\\Stream\\\\Encryption->stream_read(8192)\\n#3 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/streams\\\/src\\\/Wrapper.php(83): fread(Resource id #103, 8192)\\n#4 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/streams\\\/src\\\/CallbackWrapper.php(91): Icewind\\\\Streams\\\\Wrapper->stream_read(8192)\\n#5 [internal function]: Icewind\\\\Streams\\\\CallbackWrapper->stream_read(8192)\\n#6 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/lib\\\/composer\\\/sabre\\\/http\\\/lib\\\/Sapi.php(80): stream_copy_to_stream(Resource id #106, Resource id #108, '2222684')\\n#7 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(498): Sabre\\\\HTTP\\\\Sapi::sendResponse(Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#9 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/dav\\\/lib\\\/Server.php(298): Sabre\\\\DAV\\\\Server->exec()\\n#10 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#11 \\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/remote.php(165): require_once('\\\/var\\\/www\\\/vhosts...')\\n#12 {main}\",\"File\":\"\\\/var\\\/www\\\/vhosts\\\/***.***.de\\\/htdocs\\\/apps\\\/encryption\\\/lib\\\/Crypto\\\/Encryption.php\",\"Line\":366}"}
