I have Owncloud Server 10.7.0 running, although the problem itself already existed with older versions of the 10.x branch.
PHP Vesion is 7.4.3
MySQL 8.0.23
In my config.php I have trashbin configured like that:
If I run the cronjob manually I don’t get no output (assuming that no output means no error)
Nonetheless I have files in my trashbin that are about 2 months old.
Expected behaviour is that OC deletes files in my trashbin that are old that 14 days.
Does anyone have a hint for me how I can fix this or can anyone confirm this as a bug?
Bye, Dirk
I guess nothing was deleted because there is too much space left on the device. (I’m referring to the docs about trashbin_purge_limit “This setting defines the percentage of free space occupied by deleted files that triggers auto purging of deleted files for this user”)
Is there no easy way left to delete files in thrashbin after X time ?
If I understand the docs right it should be
‘trashbin_retention_obligation’ => ‘14, 14’,
From the docs for trashbin_retention_obligation: " D1, D2 keep files and folders in the trash bin for at least D1 days and delete when exceeds D2 days"
Hi, Yes, the storage from ownCloud should have symlinks, there is a trick and you could use them, but I would not recommend because you could have additional problems as you now experiented
