- Access Owncloud via cloud.example-group.de
- Get error “Domain is not trustworthy”, add domain to “owncloud/config/config.php”
- Access Owncloud via cloud.example-group.de again
Domain should now be trustworthy
Domain is still not trustworthy
Operating system: Ubuntu 18_04 LTS Desktop
Web server: Apache2
PHP version: PHP 7.2
ownCloud version: 10.0.9
Updated from an older ownCloud or fresh install: Fresh and clean ;D
Where did you install ownCloud from: Official repositories
‘trusted_domains’ =>
array (
0 => ‘server.example-domain.de’,
1 => ‘cloud.example-group.de’,
2 => ‘localhost’,
3 => ‘$ip-address’,
4 => ‘cloud.example-domain.de’,
List of activated apps: LDAP
Are you using encryption: No
Are you using an external user-backend, if yes which one: LDAP -> ActiveDirectory
Browser: Google Chrome
Operating system: Android 8.0.0, Windows 10
PROBLEM:
So our domain is: example-domain.de, while our website is example-group.de
The owncloud-server is server.example-domain.de and the cloud can be accessed nor problemo via “server.example-domain.de”, “cloud.example-domain.de”, “cloud.example-group.de”, and “$ip-address”, as long as I’m using a PC that is in the domain-network.
When trying my phone, (or a notebook using a hotspot my phone delivers) I can’t access the cloud via the “example-domain.de”-adresses of course, as it is not in the domain. But when I’m trying the "cloud.example-group.de"address, it gives me the error of the accessing domain not being trustworthy and I should add it into the trusted_domains.
(In our DNS “cloud.example-group.de” points to “$ip-address”)
So how can I make the “cloud.example-group.de” trusted? (Except by adding it to trusted_domains?)
