Trusted domains not working
I’ve set up an owncloud server in docker, and while it appears to be perfectly functional nothing I try no matter the different variations will make the trusted domains work. I’ve followed everything in the documentation exactly, and the file is definitely in use - if I intentionally mess up the format it’s loaded, but it will not implement any functionality it’s supposed to.
  1. Started a new owncloud server
  2. Whitelisted local ip and WAN hostname
  3. Attempt to connect on anything other than localhost
Connecting to the service should work
I received a trusted domain error no matter what is attempted
Windows 10
apache
sqlite
10.12.1 stable
fresh install
github via docker desktop
Config.php
<?php
$CONFIG = array (
  'apps_paths' =>
  array (
    0 =>
    array (
      'url' => '/apps',
      'writable' => false,
    1 =>
    array (
      'path' => '/var/www/owncloud/custom',
      'url' => '/custom',
      'writable' => true,
  'trusted_domains' => array (
    0 => 'localhost',
    1 => '192.168.50.2',
  'domain' => 'localhost',
  'datadirectory' => '/mnt/data/files',
  'dbtype' => 'sqlite',
  'log_type' => 'owncloud',
  'supportedDatabases' =>
  array (
    0 => 'sqlite',
    1 => 'mysql',
    2 => 'pgsql',
  'upgrade.disable-web' => true,
  'default_language' => 'en',
  'overwrite.cli.url' => 'thebdf.org',
  'htaccess.RewriteBase' => '/',
  'logfile' => '/mnt/data/files/owncloud.log',
  'passwordsalt' => 'IsHKalVg9iJKTDO+qHBUmPIZjFIQTW',
  'secret' => 'Oo/+BJrVFRPVheHRMjTMx2+JweR/5mFL7fJBTk5guqkcQhwz',
  'version' => '10.12.1.3',
  'allow_user_to_change_mail_address' => '',
  'logtimezone' => 'UTC',
  'installed' => true,
  'instanceid' => 'ocpp9apit2p5',
Not using external storage
Not using encryption
Not using external backend or LDAP
Chrome
Windows 10
Hello, please take a look at Trusted domains - #34 by rkaussow
Thanks for the heads up. It could potentially be useful for the error dialogue that pops up to make note of the possibility of different settings for docker, at least. It would be even more ideal to not use a whole different system for docker, but I’m guessing there’s a complicated technical reason that’s done.
i think the reason why it currently can’t be done has been given here:
