Cannot connect via LAN or web to my server when /var/www/html/owncloud/config/config.php has overwrite.cli.url set to https://myWANip/owncloud
Raspbian
apache2
mysql
installed 7.2, but 7.3 seems to be running?
10.0.10
Fresh
https://download.owncloud.org/community/owncloud-10.0.10.tar.bz2
<?php
$CONFIG = array (
'instanceid' => 'xxxxxxxxxxxxxxxxxxx',
'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxxx',
'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxx',
'trusted_domains' =>
array (
0 => '10.0.0.148',
1 => 'wan ip',
'datadirectory' => '/var/www/html/owncloud/data',
'overwrite.cli.url' => 'https://wan ip/owncloud',
'dbtype' => 'mysql',
'version' => '10.0.10.4',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'dbuser' => 'me',
'dbpassword' => 'mypass',
'logtimezone' => 'UTC',
'installed' => true,
pi@raspberrypi:/var/www/html/owncloud $ sudo -u www-data php occ config:list system
This version of ownCloud is not compatible with PHP 7.3
You are currently running PHP 7.3.4-2.
pi@raspberrypi:/var/www/html/owncloud $ cd
pi@raspberrypi:~ $ a2dismod php7.3
ERROR: Module php7.3 does not exist!
pi@raspberrypi:~ $ sudo a2dismod php7.3
pi@raspberrypi:~ $ a2enmod php7.2
Considering dependency mpm_prefork for php7.2:
Considering conflict mpm_event for mpm_prefork:
Considering conflict mpm_worker for mpm_prefork:
Module mpm_prefork already enabled
Considering conflict php5 for php7.2:
Module php7.2 already enabled
pi@raspberrypi:~ $
no
