After upgrading to Owncloud 10.12.2.1, as usual, a message appears on files which are no longer needed. All these files have been removed now.
However, now we get a message on 2 files which are not present. It doesn’t seem to affect Owncloud because we can still use it. I generated a Config report but this only confirms 2 files are missing. We are using an Ubuntu 20 webserver and we always install updates as soon as they are available. I checked the update file we used for the update but the 2 files are not there. How can we solve this. The error message reads:
Technical information
them.
You can safely ignore those files because they’re for development. They shouldn’t be in the signature file though. In any case, they won’t affect the app behavior in any way.
You can check if there is a new version of the richdocuments app and install it. The alternative is to ignore the app signature (Config.php Parameters :: ownCloud Documentation should work) although you should remove that configuration the next time you upgrade that app
The issue was resolved by downloading the latest version of the app. After extracting the files I copied the 2 missing files to the subdirectories mentioned earlier. The app was already installed but 2 files were missing.
