Ubuntu release upgrade 16.4 to 18.4: cURL issue
I had a working installation on Ubuntu 16.04 server, and I got problems after Ubuntu 18.04.1 release upgrade.
Is that: normal, known ?
Have I to reinstall owncloud from scratch ?
  1. Performed Ubuntu 18.4 release upgrade
  2. NOR removed old packet during upgrade
  3. Try to access owncloud service
I would expect to access owncloud service without problems
Client installed on workstation PC claim: user disconnected.
Service WEB page (my.domain/owncloud/ states: PHP cURL module not installed
Ubuntu 18.04.01
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2018-10-10T18:59:25
mysql Ver 14.14 Distrib 5.7.24, for Linux (x86_64) using EditLine wrapper
PHP 7.2.10-0ubuntu0.18.04.1 (cli) (built: Sep 13 2018 13:45:02) ( NTS )
“version”: “10.0.10.4”
Updated from previous release
owncloud repository
Cannot login
“system”: {
“instanceid”: “ocduitoeglfj”,
“trusted_domains”: [
zappi.me
“datadirectory”: “/var/www/zappi.me/public_html/owncloud/data”,
“overwrite.cli.url”: “http://localhost”,
“dbtype”: “mysql”,
“version”: “10.0.10.4”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“logtimezone”: “UTC”,
“installed”: true,
“maintenance”: false,
“loglevel”: 2
Enabled:
  • comments: 0.3.0
  • configreport: 0.1.1
  • dav: 0.4.0
  • federatedfilesharing: 0.3.1
  • federation: 0.1.0
  • files: 1.5.1
  • files_external: 0.7.1
  • files_sharing: 0.11.0
  • files_trashbin: 0.9.1
  • files_versions: 1.3.0
  • files_videoplayer: 0.9.8
  • firstrunwizard: 1.1
  • market: 0.2.5
  • notifications: 0.3.5
  • provisioning_api: 0.5.0
  • systemtags: 0.3.0
  • updatenotification: 0.2.1
    Disabled:
  • encryption
  • external
  • user_external
No
Use https with certificate, if this was the question.
No
Firefox 63.0.3
Windows 10 PRO Ver. 1803
https://github.com/LucaZeta/Logs/blob/master/owncloud.log
#### Browser log
c) …
i think while moving from Ubuntu 16.04 to 18.04 you have also updated the PHP (e.g. from PHP 5.6 to 7.0) but missed to make sure that all previously PHP extensions of 5.6 are also installed for 7.0.
God idea tom42,
curl extention looks installed for both php.7.0 and php.7.2:
user@host: locate mods-available | grep -i curl
/etc/php/7.0/mods-available/curl.ini
/etc/php/7.2/mods-available/curl.ini
/var/lib/ucf/cache/:etc:php:7.0:mods-available:curl.ini
/var/lib/ucf/cache/:etc:php:7.2:mods-available:curl.ini
then I tried to:
sudo phpenmod curl
sudo service apache2 restart
But curl looks to owncloud server stll as not installed.
If you known some other procedure to follow, you will be welcome.
maybe you could ask in an Ubuntu forums or the support of your hoster how to correctly migrate a PHP installation so that the required modules are correctly enabled and provided to PHP applications like ownCloud?
I agree with @anon21401411, that this is highly off-topic.
