- Install External Storage FTP
- Add FTP as external Storage
- Enter Username/Password/Host/Port
- Leave the Root blank
- Add the Connection
FTP Connection Successfull, and after adding the External Storage, start the Files scan using “sudo -u www-data php files:scan -all”
A red square appears, not allowing the FTP connection to be established. Error Code shows: There was an error with message: League\Flysystem\FileNotFoundException: File not found at path: . Do you want to review mount point config in admin settings page?
Operating system: Ubuntu Server 18.04.3
Web server: Apache2
Database: MariaDB
PHP version: 7.2
ownCloud version: 10.3.1.1
Updated from an older ownCloud or fresh install:* Fresh install
Where did you install ownCloud from: Tarball
Not Changed
Are you using external storage, if yes which one: ftp
Are you using encryption: no
Are you using an external user-backend, if yes which one: None
Browser: Chrome
Operating system: Windows 10
