Hi, I am currently testing Owncloud with an enterprise Trial.
I mounted an external storage using the Windows Drive app.
I can see the files, I can download the files but I can’t upload.
Upload “kinda” works, I see the file when I access the network share but it shows a .part file that once renamed to its original name is working as intended (tried to upload a PDF file that was renamed by Owncloud to a .PART file, I renamed it back to PDF and it worked). but for some reasons Owncloud is not able to rename it I believe?
As a result, the client or Web UI report the following errors.
The file is being uploaded to the SMB share
The client report an error :
A HTTP transmission error happened. : The server file discovery reply is missing data.
Server replied “503 Service Unavailable” to “PUT …” (Failed to check file size: )
- Install owncloud (tested with Appliance for VirtualBox and Self install on Ubuntu server latest version)
- Mount SMB using the owncloud GUI
- Synchronize with the owncloud client
- Try to add a file to the SMB share
Operating system: Ubuntu server 18.04
Web server: Apache2
PHP version: 7.2
ownCloud version: 10.0.10
Storage backend (external storage): Windows Server 2016 SMB share
Client version: 2.5.1
Operating system: Windows 10 1809
OS language: EN
Installation path of client: C:\Program Files (x86)\ownCloud
Client logfile:
Server replied “503 Service Unavailable” to “PUT …” (Failed to check file size: ) -
Web server error log:
{“reqId”:“1d02692c-0e9b-473b-a8c8-1778f1d1926d”,“level”:4,“time”:“2019-01-25T12:39:38+00:00”,“remoteAddr”:“192.168.1.131”,“user”:“5E08A3B5-F46D-4655-915B-449C6EE67BCE”,“app”:“webdav”,“method”:“PUT”,“url”:"/remote.php/dav/files/5E08A3B5-F46D-4655-915B-449C6EE67BCE/New%20Share/Massiot%20Alexandre/ownCloud%20Manual.pdf",“message”:“Exception: HTTP/1.1 503 Failed to check file size: : {“Exception”:“Sabre\\DAV\\Exception\\ServiceUnavailable”,“Message”:“Failed to check file size: “,“Code”:0,“Trace”:”#0 \/var\/www\/html\/apps\/dav\/lib\/Connector\/Sabre\/Directory.php(172): OCA\\DAV\\Connector\\Sabre\\File->put(Resource id #75)\n#1 \/var\/www\/html\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(1095): OCA\\DAV\\Connector\\Sabre\\Directory->createFile(‘ownCloud Manual…’, Resource id #75)\n#2 \/var\/www\/html\/lib\/composer\/sabre\/dav\/lib\/DAV\/CorePlugin.php(525): Sabre\\DAV\\Server->createFile(‘files\/5E08A3B5-…’, Resource id #75, NULL)\n#3 [internal function]: Sabre\\DAV\\CorePlugin->httpPut(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#4 \/var\/www\/html\/lib\/composer\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#5 \/var\/www\/html\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(479): Sabre\\Event\\EventEmitter->emit(‘method:PUT’, Array)\n#6 \/var\/www\/html\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#7 \/var\/www\/html\/apps\/dav\/lib\/Server.php(298): Sabre\\DAV\\Server->exec()\n#8 \/var\/www\/html\/apps\/dav\/appinfo\/v2\/remote.php(31): OCA\\DAV\\Server->exec()\n#9 \/var\/www\/html\/remote.php(165): require_once(’\/var\/www\/html\/a…’)\n#10 {main}”,“File”:”\/var\/www\/html\/apps\/dav\/lib\/Connector\/Sabre\/File.php",“Line”:291}"}
Thanks for your help!
AM.
