Unable to use SMB External Storage
Hi, there
I’m having troubles when I am trying to access a SMB external storage folder on my onwcloud server. I was able to add it, as you can see bellow:
But, when I try to access it, owncloud keeps showing me the following error: Storage for “/” is temporarily not available
It seems that smbclient is working just fine. I was able to query my external storage shares from command line
Ex: smbclient -L <file_server_name> -U <full_domain_name>/<user_name>
Does anyone ever faced these kind of problems?
Operating system : Linux 4.18.0-372.9.1.el8.x86_64 Red Hat Enterprise Linux 8.6 (Ootpa)
**Web server:Apache 2.4.37-47
**Database: Maria DB 3:10.3.32-2
**PHP version:7.4
**ownCloud version: 10.11 fresh install
**Where did you install ownCloud from: https://download.owncloud.com/server/stable/owncloud-complete-latest.zip
“system”: {
“instanceid”: “oc3jkl3tutyn”,
“trusted_domains”: [
“localhost”,
“s6022autfs00.petroaut.biz”,
“10.236.160.34”
“datadirectory”: “/var/www/html/owncloud/data”,
“overwrite.cli.url”: “https://s6022autfs00.petroaut.biz/owncloud”,
“dbtype”: “mysql”,
“version”: “10.11.0.6”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“allow_user_to_change_mail_address”: “”,
“logtimezone”: “UTC”,
“apps_paths”: [
“path”: “/var/www/html/owncloud/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/html/owncloud/apps-external”,
“url”: “/apps-external”,
“writable”: true
“installed”: true,
“loglevel”: 0,
“smb.logging.enable”: true,
“memcache.local”: “\OC\Memcache\APCu”,
“ldapIgnoreNamingRules”: false
Enabled:
  • activity:
    • Version: 2.7.1
    • Path: /var/www/html/owncloud/apps/activity
  • comments:
    • Version: 0.3.0
    • Path: /var/www/html/owncloud/apps/comments
  • configreport:
    • Version: 0.2.1
    • Path: /var/www/html/owncloud/apps/configreport
  • dav:
    • Version: 0.7.0
    • Path: /var/www/html/owncloud/apps/dav
  • federatedfilesharing:
    • Version: 0.5.0
    • Path: /var/www/html/owncloud/apps/federatedfilesharing
  • federation:
    • Version: 0.1.0
    • Path: /var/www/html/owncloud/apps/federation
  • files:
    • Version: 1.5.2
    • Path: /var/www/html/owncloud/apps/files
  • files_external:
    • Version: 0.9.0
    • Path: /var/www/html/owncloud/apps/files_external
  • files_mediaviewer:
    • Version: 1.0.5
    • Path: /var/www/html/owncloud/apps/files_mediaviewer
  • files_pdfviewer:
    • Version: 1.0.1
    • Path: /var/www/html/owncloud/apps/files_pdfviewer
  • files_sharing:
    • Version: 0.14.0
    • Path: /var/www/html/owncloud/apps/files_sharing
  • files_texteditor:
    • Version: 2.4.1
    • Path: /var/www/html/owncloud/apps/files_texteditor
  • files_trashbin:
    • Version: 0.9.1
    • Path: /var/www/html/owncloud/apps/files_trashbin
  • files_versions:
    • Version: 1.3.0
    • Path: /var/www/html/owncloud/apps/files_versions
  • firstrunwizard:
    • Version: 1.2.0
    • Path: /var/www/html/owncloud/apps/firstrunwizard
  • market:
    • Version: 0.7.0
    • Path: /var/www/html/owncloud/apps/market
  • notifications:
    • Version: 0.5.4
    • Path: /var/www/html/owncloud/apps/notifications
  • provisioning_api:
    • Version: 0.5.0
    • Path: /var/www/html/owncloud/apps/provisioning_api
  • systemtags:
    • Version: 0.3.0
    • Path: /var/www/html/owncloud/apps/systemtags
  • templateeditor:
    • Version: 0.4.0
    • Path: /var/www/html/owncloud/apps/templateeditor
  • updatenotification:
    • Version: 0.2.1
    • Path: /var/www/html/owncloud/apps/updatenotification
  • user_ldap:
    • Version: 0.16.0
    • Path: /var/www/html/owncloud/apps/user_ldap
Are you using external storage, if yes which one: smb
Are you using an external user-backend, if yes which one: ActiveDirectory
**Browser :Firefox 76 (64bits)
**Operating system:Windows 2019 Server
"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2F","message":"enter: __construct({\"host\":\"ssprcpvfs10114.petroaut.biz\",\"share\":\"PRD_AREATRANSF_001$\",\"root\":\"AreaTransf\",\"domain\":\"petroaut\",\"user\":\"petroaut\\\\sargnoc\",\"password\":\"***removed***\"})"}
{"reqId":"Y2usXBqovyWEPP@vxp-NZgAAAE8","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2F","message":"using Icewind\\SMB\\Wrapped\\Share for the connection"}
{"reqId":"Y2usXBqovyWEPP@vxp-NZgAAAE8","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2F","message":"leave: __construct, getId:smb::petroaut\\sargnoc@ssprcpvfs10114.petroaut.biz\/\/PRD_AREATRANSF_001$\/\/AreaTransf\/"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJAAAAIE","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"OC\\User\\Session::validateToken","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"token 0011a323b1e76a54f2125be419b51832c3f7b91866b524c380c8ad6040be98a3e4a31f6c1784c74bf902375599ae51b0b8a7ccf70a738580d82cbf098bdbc574 with token id 13 found, validating"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJAAAAIE","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"enter: __construct({\"host\":\"ssprcpvfs10114.petroaut.biz\",\"share\":\"PRD_AREATRANSF_001$\",\"root\":\"AreaTransf\",\"domain\":\"petroaut\",\"user\":\"petroaut\\\\sargnoc\",\"password\":\"***removed***\"})"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJAAAAIE","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"using Icewind\\SMB\\Wrapped\\Share for the connection"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJAAAAIE","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"leave: __construct, getId:smb::petroaut\\sargnoc@ssprcpvfs10114.petroaut.biz\/\/PRD_AREATRANSF_001$\/\/AreaTransf\/"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"OC\\User\\Session::validateToken","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"token 0011a323b1e76a54f2125be419b51832c3f7b91866b524c380c8ad6040be98a3e4a31f6c1784c74bf902375599ae51b0b8a7ccf70a738580d82cbf098bdbc574 with token id 13 found, validating"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: __construct({\"host\":\"ssprcpvfs10114.petroaut.biz\",\"share\":\"PRD_AREATRANSF_001$\",\"root\":\"AreaTransf\",\"domain\":\"petroaut\",\"user\":\"petroaut\\\\sargnoc\",\"password\":\"***removed***\"})"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"using Icewind\\SMB\\Wrapped\\Share for the connection"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"leave: __construct, getId:smb::petroaut\\sargnoc@ssprcpvfs10114.petroaut.biz\/\/PRD_AREATRANSF_001$\/\/AreaTransf\/"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: test()"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: stat()"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: getFileInfo()"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: buildPath()"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"leave: buildPath, return '\/AreaTransf'"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"stat fetching '\/AreaTransf'"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":0,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"leave: getFileInfo, throw OCP\\Files\\StorageNotAvailableException - code: 0 message:  trace: #0 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(364): OCA\\Files_External\\Lib\\Storage\\SMB->getFileInfo()\n#1 \/var\/www\/html\/owncloud\/lib\/private\/Files\/Storage\/Common.php(452): OCA\\Files_External\\Lib\\Storage\\SMB->stat()\n#2 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(741): OC\\Files\\Storage\\Common->test()\n#3 \/var\/www\/html\/owncloud\/lib\/private\/Files\/External\/LegacyUtil.php(207): OCA\\Files_External\\Lib\\Storage\\SMB->test()\n#4 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Controller\/StoragesController.php(254): OC\\Files\\External\\LegacyUtil::getBackendStatus()\n#5 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Controller\/UserGlobalStoragesController.php(124): OCA\\Files_External\\Controller\\StoragesController->updateStorageStatus()\n#6 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(170): OCA\\Files_External\\Controller\\UserGlobalStoragesController->show()\n#7 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(89): OC\\AppFramework\\Http\\Dispatcher->executeController()\n#8 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/App.php(100): OC\\AppFramework\\Http\\Dispatcher->dispatch()\n#9 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(47): OC\\AppFramework\\App::main()\n#10 \/var\/www\/html\/owncloud\/lib\/private\/Route\/Router.php(344): OC\\AppFramework\\Routing\\RouteActionHandler->__invoke()\n#11 \/var\/www\/html\/owncloud\/lib\/base.php(914): OC\\Route\\Router->match()\n#12 \/var\/www\/html\/owncloud\/index.php(54): OC::handleRequest()\n#13 {main}"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":3,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"files_external","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"Exception: {\"Exception\":\"OCP\\\\Files\\\\StorageNotAvailableException\",\"Message\":\"\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(364): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->getFileInfo()\\n#1 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Common.php(452): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->stat()\\n#2 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(741): OC\\\\Files\\\\Storage\\\\Common->test()\\n#3 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/External\\\/LegacyUtil.php(207): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->test()\\n#4 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(254): OC\\\\Files\\\\External\\\\LegacyUtil::getBackendStatus()\\n#5 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/UserGlobalStoragesController.php(124): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus()\\n#6 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(170): OCA\\\\Files_External\\\\Controller\\\\UserGlobalStoragesController->show()\\n#7 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(89): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController()\\n#8 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/App.php(100): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch()\\n#9 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main()\\n#10 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Route\\\/Router.php(344): OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke()\\n#11 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/base.php(914): OC\\\\Route\\\\Router->match()\\n#12 \\\/var\\\/www\\\/html\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#13 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php\",\"Line\":193}"}
{"reqId":"Y2usXK5tFL3WP8Du6dmiJQAAAIY","level":3,"time":"2022-11-09T13:34:20+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"files_external","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"Caused by: {\"Exception\":\"Icewind\\\\SMB\\\\Exception\\\\ConnectionRefusedException\",\"Message\":\"\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Wrapped\\\/Share.php(114): Icewind\\\\SMB\\\\Wrapped\\\\Connection->clearTillPrompt()\\n#1 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Wrapped\\\/Share.php(128): Icewind\\\\SMB\\\\Wrapped\\\\Share->getConnection()\\n#2 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Wrapped\\\/Share.php(457): Icewind\\\\SMB\\\\Wrapped\\\\Share->connect()\\n#3 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Wrapped\\\/Share.php(176): Icewind\\\\SMB\\\\Wrapped\\\\Share->execute()\\n#4 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Wrapped\\\/Share.php(197): Icewind\\\\SMB\\\\Wrapped\\\\Share->dir()\\n#5 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(151): Icewind\\\\SMB\\\\Wrapped\\\\Share->stat()\\n#6 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(364): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->getFileInfo()\\n#7 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Common.php(452): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->stat()\\n#8 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(741): OC\\\\Files\\\\Storage\\\\Common->test()\\n#9 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/External\\\/LegacyUtil.php(207): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->test()\\n#10 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(254): OC\\\\Files\\\\External\\\\LegacyUtil::getBackendStatus()\\n#11 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/UserGlobalStoragesController.php(124): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus()\\n#12 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(170): OCA\\\\Files_External\\\\Controller\\\\UserGlobalStoragesController->show()\\n#13 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(89): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController()\\n#14 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/App.php(100): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch()\\n#15 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main()\\n#16 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Route\\\/Router.php(344): OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke()\\n#17 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/base.php(914): OC\\\\Route\\\\Router->match()\\n#18 \\\/var\\\/www\\\/html\\\/owncloud\\\/index.php(54): OC::handleRequest()\\n#19 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Wrapped\\\/Connection.php\",\"Line\":57}"}
{"reqId":"Y2usXq5tFL3WP8Du6dmiJgAAAJc","level":0,"time":"2022-11-09T13:34:22+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"OC\\User\\Session::validateToken","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"token 0011a323b1e76a54f2125be419b51832c3f7b91866b524c380c8ad6040be98a3e4a31f6c1784c74bf902375599ae51b0b8a7ccf70a738580d82cbf098bdbc574 with token id 13 found, validating"}
{"reqId":"Y2usXq5tFL3WP8Du6dmiJgAAAJc","level":0,"time":"2022-11-09T13:34:22+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"enter: __construct({\"host\":\"ssprcpvfs10114.petroaut.biz\",\"share\":\"PRD_AREATRANSF_001$\",\"root\":\"AreaTransf\",\"domain\":\"petroaut\",\"user\":\"petroaut\\\\sargnoc\",\"password\":\"***removed***\"})"}
{"reqId":"Y2usXq5tFL3WP8Du6dmiJgAAAJc","level":0,"time":"2022-11-09T13:34:22+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"using Icewind\\SMB\\Wrapped\\Share for the connection"}
{"reqId":"Y2usXq5tFL3WP8Du6dmiJgAAAJc","level":0,"time":"2022-11-09T13:34:22+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"leave: __construct, getId:smb::petroaut\\sargnoc@ssprcpvfs10114.petroaut.biz\/\/PRD_AREATRANSF_001$\/\/AreaTransf\/"}
{"reqId":"Y2usYRqovyWEPP@vxp-NaQAAAEA","level":0,"time":"2022-11-09T13:34:25+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"OC\\User\\Session::validateToken","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ocadmin\/Area%20Transferencia","message":"token 0011a323b1e76a54f2125be419b51832c3f7b91866b524c380c8ad6040be98a3e4a31f6c1784c74bf902375599ae51b0b8a7ccf70a738580d82cbf098bdbc574 with token id 13 found, validating"}
{"reqId":"Y2usYRqovyWEPP@vxp-NaQAAAEA","level":0,"time":"2022-11-09T13:34:25+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ocadmin\/Area%20Transferencia","message":"enter: __construct({\"host\":\"ssprcpvfs10114.petroaut.biz\",\"share\":\"PRD_AREATRANSF_001$\",\"root\":\"AreaTransf\",\"domain\":\"petroaut\",\"user\":\"petroaut\\\\sargnoc\",\"password\":\"***removed***\"})"}
{"reqId":"Y2usYRqovyWEPP@vxp-NaQAAAEA","level":0,"time":"2022-11-09T13:34:25+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ocadmin\/Area%20Transferencia","message":"using Icewind\\SMB\\Wrapped\\Share for the connection"}
{"reqId":"Y2usYRqovyWEPP@vxp-NaQAAAEA","level":0,"time":"2022-11-09T13:34:25+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"smb","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ocadmin\/Area%20Transferencia","message":"leave: __construct, getId:smb::petroaut\\sargnoc@ssprcpvfs10114.petroaut.biz\/\/PRD_AREATRANSF_001$\/\/AreaTransf\/"}
{"reqId":"Y2usYRqovyWEPP@vxp-NaQAAAEA","level":0,"time":"2022-11-09T13:34:25+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"no app in context","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ocadmin\/Area%20Transferencia","message":"Lock files\/d3520b2c5e90e3d7c6b01450fe067888\/1 already exists"}
{"reqId":"Y2usYRqovyWEPP@vxp-NaQAAAEA","level":0,"time":"2022-11-09T13:34:25+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"no app in context","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ocadmin\/Area%20Transferencia","message":"Lock files\/76f6275cc15ee0aa8990295bd974b9aa\/-1 already exists"}
{"reqId":"Y2usYRqovyWEPP@vxp-NaQAAAEA","level":0,"time":"2022-11-09T13:34:25+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"webdav","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ocadmin\/Area%20Transferencia","message":"Exception: HTTP\/1.1 503 Storage is temporarily not available: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\ServiceUnavailable\",\"Message\":\"Storage is temporarily not available\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Tree.php(70): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\ObjectTree->getNodeForPath()\\n#1 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/FilesPlugin.php(183): OCA\\\\DAV\\\\Tree->getNodeForPath()\\n#2 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(89): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\FilesPlugin->checkPropFind()\\n#3 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(472): Sabre\\\\DAV\\\\Server->emit()\\n#4 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(253): Sabre\\\\DAV\\\\Server->invokeMethod()\\n#5 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(349): Sabre\\\\DAV\\\\Server->start()\\n#6 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/html\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/html\\\/o...')\\n#8 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/ObjectTree.php\",\"Line\":181}"}
{"reqId":"Y2usYRqovyWEPP@vxp-NaQAAAEA","level":0,"time":"2022-11-09T13:34:25+00:00","remoteAddr":"10.30.177.94","user":"ocadmin","app":"webdav","method":"PROPFIND","url":"\/remote.php\/dav\/files\/ocadmin\/Area%20Transferencia","message":"Caused by: {\"Exception\":\"OCP\\\\Files\\\\StorageNotAvailableException\",\"Message\":\"\",\"Code\":1,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(457): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->checkAvailability()\\n#1 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Encryption.php(177): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->getMetaData()\\n#2 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Checksum.php(207): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Encryption->getMetaData()\\n#3 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(587): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Checksum->getMetaData()\\n#4 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(115): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getMetaData()\\n#5 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(152): OC\\\\Files\\\\Cache\\\\Scanner->getData()\\n#6 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(329): OC\\\\Files\\\\Cache\\\\Scanner->scanFile()\\n#7 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/View.php(1410): OC\\\\Files\\\\Cache\\\\Scanner->scan()\\n#8 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/View.php(1453): OC\\\\Files\\\\View->getCacheEntry()\\n#9 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/ObjectTree.php(179): OC\\\\Files\\\\View->getFileInfo()\\n#10 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Tree.php(70): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\ObjectTree->getNodeForPath()\\n#11 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/FilesPlugin.php(183): OCA\\\\DAV\\\\Tree->getNodeForPath()\\n#12 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/WildcardEmitterTrait.php(89): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\FilesPlugin->checkPropFind()\\n#13 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(472): Sabre\\\\DAV\\\\Server->emit()\\n#14 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(253): Sabre\\\\DAV\\\\Server->invokeMethod()\\n#15 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(349): Sabre\\\\DAV\\\\Server->start()\\n#16 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#17 \\\/var\\\/www\\\/html\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/html\\\/o...')\\n#18 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php\",\"Line\":75}"}
Install the libsmbclient-php library (and check that the server is using it) and retry.
Hi @jvillafanez,
I was not using it, thanks fo the tip. I mannaged to install the libsmbclient-php-1.0.6, and now I am getting a red square that indicates that I was not abble to mount my smb share. The owncloud.log points to a “throw Icewind\SMB\Exception\ForbiddenException - code: 13 message: Invalid request for /AreaTransf (ForbiddenException)”, as you can see bellow
{"reqId":"Y24vLAhH7WrnjVSeA4uXBgAAAIY","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2F","message":"enter: __construct({\"host\":\"ssprcpvfs10114.petroaut.biz\",\"share\":\"PRD_AREATRANSF_001$\",\"root\":\"AreaTransf\",\"domain\":\"petroaut\",\"user\":\"petroaut\\\\sargnoc\",\"password\":\"***removed***\"})"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXBgAAAIY","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2F","message":"using Icewind\\SMB\\Native\\NativeShare for the connection"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXBgAAAIY","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files\/ajax\/getstoragestats.php?dir=%2F","message":"leave: __construct, getId:smb::petroaut\\sargnoc@ssprcpvfs10114.petroaut.biz\/\/PRD_AREATRANSF_001$\/\/AreaTransf\/"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXBwAAAIc","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"OC\\User\\Session::validateToken","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"token 404bb07c39a50791a1713bd3d9f02eab9122047a02990d5c6a7a7fdbedf00512880638f9adcea2b3d114d8b91e8d84eedd1077a0dcff15f1bae8be9c7ee3230e with token id 25 found, validating"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXBwAAAIc","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"enter: __construct({\"host\":\"ssprcpvfs10114.petroaut.biz\",\"share\":\"PRD_AREATRANSF_001$\",\"root\":\"AreaTransf\",\"domain\":\"petroaut\",\"user\":\"petroaut\\\\sargnoc\",\"password\":\"***removed***\"})"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXBwAAAIc","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"using Icewind\\SMB\\Native\\NativeShare for the connection"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXBwAAAIc","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/ocs\/v1.php\/apps\/files_external\/api\/v1\/mounts?format=json","message":"leave: __construct, getId:smb::petroaut\\sargnoc@ssprcpvfs10114.petroaut.biz\/\/PRD_AREATRANSF_001$\/\/AreaTransf\/"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"OC\\User\\Session::validateToken","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"token 404bb07c39a50791a1713bd3d9f02eab9122047a02990d5c6a7a7fdbedf00512880638f9adcea2b3d114d8b91e8d84eedd1077a0dcff15f1bae8be9c7ee3230e with token id 25 found, validating"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: __construct({\"host\":\"ssprcpvfs10114.petroaut.biz\",\"share\":\"PRD_AREATRANSF_001$\",\"root\":\"AreaTransf\",\"domain\":\"petroaut\",\"user\":\"petroaut\\\\sargnoc\",\"password\":\"***removed***\"})"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"using Icewind\\SMB\\Native\\NativeShare for the connection"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"leave: __construct, getId:smb::petroaut\\sargnoc@ssprcpvfs10114.petroaut.biz\/\/PRD_AREATRANSF_001$\/\/AreaTransf\/"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: test()"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: stat()"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: getFileInfo()"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: buildPath()"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"leave: buildPath, return '\/AreaTransf'"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"stat fetching '\/AreaTransf'"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"enter: remoteIsShare"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"leave: remoteIsShare, return false"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"leave: getFileInfo, throw Icewind\\SMB\\Exception\\ForbiddenException - code: 13 message: Invalid request for \/AreaTransf (ForbiddenException) trace: #0 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeState.php(75): Icewind\\SMB\\Exception\\Exception::fromMap()\n#1 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeState.php(92): Icewind\\SMB\\Native\\NativeState->handleError()\n#2 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeState.php(351): Icewind\\SMB\\Native\\NativeState->testResult()\n#3 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeShare.php(305): Icewind\\SMB\\Native\\NativeState->getxattr()\n#4 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeFileInfo.php(43): Icewind\\SMB\\Native\\NativeShare->getAttribute()\n#5 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeFileInfo.php(69): Icewind\\SMB\\Native\\NativeFileInfo->stat()\n#6 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeShare.php(114): Icewind\\SMB\\Native\\NativeFileInfo->getSize()\n#7 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(151): Icewind\\SMB\\Native\\NativeShare->stat()\n#8 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(364): OCA\\Files_External\\Lib\\Storage\\SMB->getFileInfo()\n#9 \/var\/www\/html\/owncloud\/lib\/private\/Files\/Storage\/Common.php(452): OCA\\Files_External\\Lib\\Storage\\SMB->stat()\n#10 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(741): OC\\Files\\Storage\\Common->test()\n#11 \/var\/www\/html\/owncloud\/lib\/private\/Files\/External\/LegacyUtil.php(207): OCA\\Files_External\\Lib\\Storage\\SMB->test()\n#12 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Controller\/StoragesController.php(254): OC\\Files\\External\\LegacyUtil::getBackendStatus()\n#13 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Controller\/UserGlobalStoragesController.php(124): OCA\\Files_External\\Controller\\StoragesController->updateStorageStatus()\n#14 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(170): OCA\\Files_External\\Controller\\UserGlobalStoragesController->show()\n#15 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(89): OC\\AppFramework\\Http\\Dispatcher->executeController()\n#16 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/App.php(100): OC\\AppFramework\\Http\\Dispatcher->dispatch()\n#17 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(47): OC\\AppFramework\\App::main()\n#18 \/var\/www\/html\/owncloud\/lib\/private\/Route\/Router.php(344): OC\\AppFramework\\Routing\\RouteActionHandler->__invoke()\n#19 \/var\/www\/html\/owncloud\/lib\/base.php(914): OC\\Route\\Router->match()\n#20 \/var\/www\/html\/owncloud\/index.php(54): OC::handleRequest()\n#21 {main}"}
{"reqId":"Y24vLAhH7WrnjVSeA4uXCAAAAIk","level":0,"time":"2022-11-11T11:17:00+00:00","remoteAddr":"10.30.177.94","user":"aaczn1","app":"smb","method":"GET","url":"\/index.php\/apps\/files_external\/userglobalstorages\/1?testOnly=false","message":"stat swallowing Icewind\\SMB\\Exception\\ForbiddenException - code: 13 message: Invalid request for \/AreaTransf (ForbiddenException) trace: #0 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeState.php(75): Icewind\\SMB\\Exception\\Exception::fromMap()\n#1 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeState.php(92): Icewind\\SMB\\Native\\NativeState->handleError()\n#2 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeState.php(351): Icewind\\SMB\\Native\\NativeState->testResult()\n#3 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeShare.php(305): Icewind\\SMB\\Native\\NativeState->getxattr()\n#4 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeFileInfo.php(43): Icewind\\SMB\\Native\\NativeShare->getAttribute()\n#5 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeFileInfo.php(69): Icewind\\SMB\\Native\\NativeFileInfo->stat()\n#6 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/Native\/NativeShare.php(114): Icewind\\SMB\\Native\\NativeFileInfo->getSize()\n#7 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(151): Icewind\\SMB\\Native\\NativeShare->stat()\n#8 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(364): OCA\\Files_External\\Lib\\Storage\\SMB->getFileInfo()\n#9 \/var\/www\/html\/owncloud\/lib\/private\/Files\/Storage\/Common.php(452): OCA\\Files_External\\Lib\\Storage\\SMB->stat()\n#10 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(741): OC\\Files\\Storage\\Common->test()\n#11 \/var\/www\/html\/owncloud\/lib\/private\/Files\/External\/LegacyUtil.php(207): OCA\\Files_External\\Lib\\Storage\\SMB->test()\n#12 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Controller\/StoragesController.php(254): OC\\Files\\External\\LegacyUtil::getBackendStatus()\n#13 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Controller\/UserGlobalStoragesController.php(124): OCA\\Files_External\\Controller\\StoragesController->updateStorageStatus()\n#14 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(170): OCA\\Files_External\\Controller\\UserGlobalStoragesController->show()\n#15 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(89): OC\\AppFramework\\Http\\Dispatcher->executeController()\n#16 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/App.php(100): OC\\AppFramework\\Http\\Dispatcher->dispatch()\n#17 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(47): OC\\AppFramework\\App::main()\n#18 \/var\/www\/html\/owncloud\/lib\/private\/Route\/Router.php(344): OC\\AppFramework\\Routing\\RouteActionHandler->__invoke()\n#19 \/var\/www\/html\/owncloud\/lib\/base.php(914): OC\\Route\\Router->match()\n#20 \/var\/www\/html\/owncloud\/index.php(54): OC::handleRequest()\n#21 {main}"}
Here some info about libsmbclient-php-1.0.6 install
PHP         : /usr/bin/php
PHP_SAPI    : cli
PHP_VERSION : 7.4.19
ZEND_VERSION: 3.4.0
PHP_OS      : Linux - Linux s6022autfs00.petroaut.biz 4.18.0-372.26.1.el8_6.x86_64 #1 SMP Sat Aug 27 02:44:20 EDT 2022 x86_64
INI actual  : /usr/lib/libsmbclient-php-1.0.6/tmp-php.ini
More .INIs  :
CWD         : /usr/lib/libsmbclient-php-1.0.6
Extra dirs  :
VALGRIND    : Not used
TIME START 2022-11-10 18:22:42
Any ideas ?
code 13 is usually caused by wrong credentials, so make sure you’ve entered the right ones and that the account can access to the share without problems (you can double-check with another program)
If you password has really weird chars, maybe one of them could be causing issues. You can try with another easier password to ensure it works.
Another thing you can try is to check with wireshark or any other similar tool, that the credentials sent to the server are the right ones.
I doubled checked my credentials … They are fine
To ensure there are no credentials issues, I mounted the same SMB share through cmd line
[root@s6022autfs00 data]# mount -t cifs -o username=sargnoc,domain=petroaut //ssprcpvfs10114.petroaut.biz/PRD_AREATRANSF_001$ /mnt/SMB
[root@s6022autfs00 data]# df -h
Sist. Arq. Tam. Usado Disp. Uso% Montado em
devtmpfs 3,8G 0 3,8G 0% /dev
tmpfs 3,8G 0 3,8G 0% /dev/shm
tmpfs 3,8G 241M 3,6G 7% /run
tmpfs 3,8G 0 3,8G 0% /sys/fs/cgroup
/dev/mapper/rhel-root 35G 11G 24G 32% /
/dev/sdb1 79G 57M 75G 1% /DB
/dev/sda2 1014M 275M 740M 28% /boot
/dev/sda1 599M 5,8M 594M 1% /boot/efi
tmpfs 768M 0 768M 0% /run/user/0
//ssprcpvfs10114.petroaut.biz/PRD_AREATRANSF_001$ 20G 1,0K 20G 1% /mnt/SMB
I will try another credential with an easier Psswrd and also try to check it with wireshark
Thanks !
Hi, everyone. Well, it turns out that SELinux was preventing OwnCloud to connect with external storage. To solve the problem, I disabled it.
