Unexplained Recurrent 400 Status Codes in OwnCloud Container Logs
I’ve encountered a repetitive issue in the logs of my OwnCloud container instance where I continuously receive 400 HTTP status codes (Bad Request). Below are examples of the log entries:
::1 - - [26/Oct/2023:14:44:49 +0000] "GET / HTTP/1.0" 400 592 "-" "-"
::1 - - [26/Oct/2023:14:45:20 +0000] "GET / HTTP/1.0" 400 592 "-" "-"
::1 - - [26/Oct/2023:14:45:51 +0000] "GET / HTTP/1.0" 400 592 "-" "-"
::1 - - [26/Oct/2023:14:46:22 +0000] "GET / HTTP/1.0" 400 592 "-" "-"
Each log entry seems to suggest that there’s a GET request made from the server itself (::1 is the loopback address) to the root path of my OwnCloud instance.
However, each request results in a 400 status code, indicating a bad request.
I am puzzled about why these requests are being made and why they are failing. Is this related to an internal health check, a misconfiguration, or something else?
Thank you in advance for your assistance!
While doing tests Im realized that is part of the health check.
