happened somewhere between installations and removals of 2.9.2 and 2.10
When I uninstall Owncloud client, the small icons next to single files in explorer (blue arrows, red x,…) should also be removed.
They are still there after uninstall and restart, (Win 10), also when I single click on a file, the bottom status bar of explorer says something like “Synchronisation pending” as if I still had the client
Hard to say. Updated from 2.9.2 to 2.10. Had connection problems, uninstalled 2.10. installed 2.9.2 again. Connection problems not solved. Uninstalled 2.9.2, restart, removed all files and folders with owncloud in the name. Restart.
Little overlays next to items still there
No Idea
Client version: 2.92 and2.10
Operating system: Win 10
OS language: German
Installation path of client: ?
Thank you
