Untrusted domain
You are accessing the server from an untrusted domain.
Please contact your administrator. If you are an administrator of this example, configure the “trusted_domains” setting in config / config.php. An example configuration is provided in config / config.sample.php.
Depending on the configuration, as an administrator, you may also be able to use the button below to trust this domain
config.php
<?php $CONFIG = array ( 'instanceid' => '', 'passwordsalt' => '', 'datadirectory' => '/app/data', 'dbtype' => 'sqlite3', 'version' => '7.0.2.1', 'installed' => true, 'ldapIgnoreNamingRules' => false, 'loglevel' => '0', 'forcessl' => true, 'user_webdavauth_url' => 'https://cloud.xxxxx.xx.xxxxx', 'theme' => '', 'maintenance' => true, 'trusted_domains' => array ( 0 => 'cloud.xxxxx.xx.xxx.xx', 1 => '10.x.x.xxx' ), 'share_folder' => '/Shared', );
This version is highly outdated [1] and was releases more then 2 1/2 years ago. Please don’t run such outdated version on productive environments as this contains tons of known bugs (at least one directly related to the trusted domains feature) [1] and public security vulnerabilities [2].
When running such outdated version you’re causing e.g. effort of people helping you where the issue might be already fixed in newer available versions.
[1] Changelog - ownCloud
[2] https://owncloud.org/security/advisories/
Do you access Owncloud with one of the 2 URL’s above? If not, add the URL you use there.
As @kljhlkhglklfgh says, update your Owncloud to the most recent. For your own sake. :slight_smile:
For the trusted domains I’ve added:
  1. localhost address for the server - i.e. ‘localhost’
  2. the loopback address for the server - i.e. ‘127.0.0.1’
    (these 2 addresses allow me to access the Owncloud admin console from the server commandline if anything goes wrong)
  3. the internal IP address which the Owncloud instance is hosted on - e.g. 192.168.1.1
    (this allows me to access Owncloud admin from the local network)
  4. the Internet routable DNS name the Owncloud instance answers on - e.g. owncloud.bernard.com
    (this allows me to access Owncloud from the Internet)
I’m not sure if you need to make your OC Internet accessable, but I’d suggest you need 1, 2, 3 above.
