Update 10.0.3.3 to 10.0.6 stuck
Hello, I tried an update from 10.0.3 to 10.0.6 on a debian server, softaclous installation, via the UI updater.
For 3/4 hrs it’s stuck now, no changes in the files visible, these are some log entries:
{"reqId":"Wnf2YH8AAQEAAF3KluAAAAAD","level":3,"time":"2018-02-05T06:14:56+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/app:list","message":"Invalid argument supplied for foreach() at \/var\/www\/vhosts\/myserver.de\/owncloud.myserver.de\/lib\/composer\/symfony\/console\/Input\/ArgvInput.php#268"} {"reqId":"Wnf2YH8AAQEAAF3KluAAAAAD","level":3,"time":"2018-02-05T06:14:56+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/app:list","message":"Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php:\/\/input stream instead. at Unknown#0"} {"reqId":"Wnf2YH8AAQEAAB8qkIgAAAAG","level":3,"time":"2018-02-05T06:14:56+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/app:getpath","message":"Undefined index: argv at \/var\/www\/vhosts\/myserver.de\/owncloud.myserver.de\/lib\/composer\/symfony\/console\/Input\/ArgvInput.php#55"} {"reqId":"Wnf2YH8AAQEAAB8qkIgAAAAG","level":3,"time":"2018-02-05T06:14:56+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/app:getpath","message":"array_shift() expects parameter 1 to be array, null given at \/var\/www\/vhosts\/myserver.de\/owncloud.myserver.de\/lib\/composer\/symfony\/console\/Input\/ArgvInput.php#59"} {"reqId":"Wnf2YH8AAQEAAB8qkIgAAAAG","level":3,"time":"2018-02-05T06:14:56+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/app:getpath","message":"Invalid argument supplied for foreach() at \/var\/www\/vhosts\/myserver.de\/owncloud.myserver.de\/lib\/composer\/symfony\/console\/Input\/ArgvInput.php#268"} {"reqId":"Wnf2YH8AAQEAAB8qkIgAAAAG","level":3,"time":"2018-02-05T06:14:56+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/app:getpath","message":"Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php:\/\/input stream instead. at Unknown#0"} {"reqId":"Wnf2YH8AAQEAAHfnTqAAAAAC","level":3,"time":"2018-02-05T06:14:56+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/app:getpath","message":"Undefined index: argv at \/var\/www\/vhosts\/myserver.de\/owncloud.myserver.de\/lib\/composer\/symfony\/console\/Input\/ArgvInput.php#55"} {"reqId":"Wnf2YH8AAQEAAHfnTqAAAAAC","level":3,"time":"2018-02-05T06:14:56+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/app:getpath","message":"array_shift() expects parameter 1 to be array, null given at \/var\/www\/vhosts\/myserver.de\/owncloud.myserver.de\/lib\/composer\/symfony\/console\/Input\/ArgvInput.php#59"} {"reqId":"Wnf2YH8AAQEAAHfnTqAAAAAC","level":3,"time":"2018-02-05T06:14:56+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/app:getpath","message":"Invalid argument supplied for foreach() at \/var\/www\/vhosts\/myserver.de\/owncloud.myserver.de\/lib\/composer\/symfony\/console\/Input\/ArgvInput.php#268"} {"reqId":"Wnf2YH8AAQEAAHfnTqAAAAAC","level":3,"time":"2018-02-05T06:14:56+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/app:getpath","message":"Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php:\/\/input stream instead. at Unknown#0"} {"reqId":"Wnf2eX8AAQEAABpZumAAAAAS","level":3,"time":"2018-02-05T06:15:57+00:00","remoteAddr":"123.123.123.123","user":"--","app":"PHP","method":"POST","url":"\/index.php\/occ\/upgrade","message":"str_repeat(): Second argument has to be greater than or equal to 0 at \/var\/www\/vhosts\/myserver.de\/owncloud.myserver.de\/lib\/composer\/symfony\/console\/Helper\/ProgressBar.php#517"}
What should I do?
Cheers,
Wolf
did your ownCloud work back on 10.0.3?
What is your config.php?
Thanks for your reply. Yes, 10.0.3 worked in general, but it suffered from 423 - file locked - errors. That was the reason for the update.
Btw: these are the last entries from update.log:
[debug] Replacing public.php [debug] Replacing remote.php [debug] Replacing robots.txt [debug] Replacing status.php [debug] Replacing version.php
Chers,
Wolf
You might find this interesting:
Hm. I deleted the oc_file_locks table before, but the errors immediately came back. So it may not have been empty when starting the upgrade.
And AFAIK crons ran regularly.
can you try to start cron manually?
At the moment I cannot access the UI, it says it is in the maintainance mode. Could I do it via ssl?
ssh, yes I would recommend you try it.
I searched for it, but could not find a solution. Can you give me a hint?
Have you ran the cronjob manually?
Sorry, I’m not 100% certain about that.
In the UI, as far as I remember, cron was first set to “AJAX”, and it said “last cron done one minute before”.
I changed that setting to “system” as recommended. Next morning I came back and UI said “last cron done 5hrs ago”. I think I did not do a manual cron - not 100% certain about that.
I just tried - ssh access to my server (it’s very limited anyway) does not provide the occ command. So I’m out of the game, true? - New installation required?
do you have root access to the server?
The su command is not available. So I think - no. True?
Probably. If you can’t connect to the server as root, or execute commands with root privileges, then you can’t execute the occ commands.
I would recommend a clean install
Well. I played back the backup. ):
Thank you for your help!
No Problem, I am glad that you have a working system again :slight_smile:
