Update 10.1.1-2019-04-23 problem
Running Owncloud 10.0.10-2019-02-18 within Univention. Systema suggests update to version 10.1.1-2019-04-23 but trying the update from Univention updatercrashes the system and deletes owncloud.
Someone in Univention support suggested disabling additional owncloud app Zimbradrive, but I do not have that one installed.
Any suggestions or non destructive tests? I already had to recover from an old snapshot and reconstruct recent changes!
Thanks!
CLaudio
Please note I am adding clarifications:
Have you tried just removing your current owncloud app and installing it again?
like
univention-app remove owncloud
that removes the ownCloud installation but keeps your files
univention-app install owncloud
installs the new owncloud app.
Thank you very much Dmitry! I will try.
Hi Dmitry.
I did as you suggested, but upon reinstalling, all the apps were disabled. When I enabled them all data was gone from them.
Contacts and Calendar I was able to recover from local copies, but I miss the bookmarks, for instance.
Any suggestions as to how to get them back?
Thanks.
Claudio
There should be a full db backup in
/var/lib/univention-appcenter/apps/owncloud/data/backup/
/var/lib/univention-appcenter/backups/
Thanks Dmitry.
in /var/lib/univention-appcenter/apps/owncloud/data/backup/
I have the fil database.sql.
and in
I have the files config.php, ldap, objectsore.config.php and overwrite.config.php
Either with one or the other, How can I restore the data? Is there documentation on how to do that?
Thanks.
Claudio
In the config files you have your server configs, so restoring data out of them is not possible.
In the .sql file you have a db dump of your database. I would make a snapshot of your current machine and then restore the database out of this .sql file.
how to restore is written in our docs:
https://doc.owncloud.com/server/10.1/admin_manual/maintenance/restore.html#restore-database
