### Steps to reproduce
1. Pressing "Open updater" (tested with Firefox 47.0.1, E…dge and IE 11)
### Expected behaviour
The updater opens.
### Actual behaviour
Nothing happens.
### Server configuration
**Operating system**:
Solaris Unix (Hosted by Strato)
**Web server:**
Apache 2.2
**Database:**
MySQL 5.5.48
**PHP version:**
5.6
**ownCloud version:**
9.0.3
Manual Update from 9.0.2
https://owncloud.org
**config.php**
<?php
$CONFIG = array (
'datadirectory' => '/mnt/web024/a2/74/12345678/htdocs/owncloud_data',
'tempdirectory' => '/mnt/web024/a2/74/12345678/htdocs/owncloud/temp',
'instanceid' => '---',
'passwordsalt' => '---',
'secret' => '---',
'dbtype' => 'mysql',
'version' => '9.1.0.15',
'dbname' => '---',
'dbhost' => 'rdbms.strato.de',
'dbtableprefix' => 'oc_',
'dbuser' => '---',
'dbpassword' => '---',
'logtimezone' => 'UTC',
'log_rotate_size' => 31457280,
'installed' => true,
'forcessl' => true,
'maintenance' => false,
'trusted_domains' =>
array (
0 => 'www.abc.de',
'theme' => '',
'loglevel' => 2,
'htaccess.RewriteBase' => '/owncloud',
{"reqId":"pofC0ks8HCdrs5XWn99O","remoteAddr":"x.x.x.x","app":"PHP","message":"Undefined index: REQUEST_URI at \/mnt\/web024\/a2\/74\/12345678\/htdocs\/owncloud\/lib\/base.php#179","level":3,"time":"2016-07-21T14:39:19+00:00","method":"--","url":"--","user":"--"}
#### error-log
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] PHP Fatal error: Uncaught exception 'UnexpectedValueException' with message 'Could not parse a response for config:list --private. Please check if the current shell user can run occ command. Raw output:
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] X-Powered-By: PHP/5.6.22
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] Set-Cookie: ocenobfbc2kr=0rm1cem36gkl3qgv0n92vvkgc6; path=/; HttpOnly
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] Expires: Thu, 19 Nov 1981 08:52:00 GMT
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] Pragma: no-cache
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] Set-Cookie: oc_sessionPassphrase=xAsNtMWn37bC45F2yjbuYohfMyjR0z3xDvHH%2BXJdVRTEfhYDt9QgEPhNMhckA4AJdmzHY%2Fcws3TRSREBVMgAsKfA4YKqvHvsqyiXtuXPojBIRiyl7sOFmBbK627GBA0g; path=/; httponly
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] Content-Security-Policy:default-src 'self'; script-src 'self' 'unsafe-eval'; style-src 'self' 'unsafe-inline'; frame-src *; img-src * data: blob:; font-src 'self' data:; media-src *; connect-src *
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] X-XSS-Protection: 1; mode=block
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] X-Content-Type-Options: nosniff
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] X-Frame-Options: Sameorigin
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] X-Robots-Tag: none
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] X-Download-Options: noopen
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] X-Permitted-Cross-Domain-Policies: none
21.07.2016 16:56:27 abc.de [client xxx.xxx.xxx.xxx] Content-type: text/html; charset=UTF in /mnt/web024/a2/74/12345678/htdocs/owncloud/updater/src/Utils/OccRunner.php on line 59
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] PHP Fatal error: Uncaught exception 'UnexpectedValueException' with message 'Could not parse a response for config:list --private. Please check if the current shell user can run occ command. Raw output:
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] X-Powered-By: PHP/5.6.22
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] Set-Cookie: ocenobfbc2kr=4oi38ip9ao7cg1lvn694br0rf3; path=/; HttpOnly
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] Expires: Thu, 19 Nov 1981 08:52:00 GMT
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] Pragma: no-cache
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] Set-Cookie: oc_sessionPassphrase=4l5HEAGE1Ek5U9PItbqVM4u5mynS3xFIh79r6avh%2Bs%2ByzfoN6hhvakR1rzBPzdmXGLS%2F%2FtUNIsXdefEprihKlPQBxOZVn1QizTZ3qtsOWkPSP484G0PvT4uSjMAtL3NI; path=/; httponly
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] Content-Security-Policy:default-src 'self'; script-src 'self' 'unsafe-eval'; style-src 'self' 'unsafe-inline'; frame-src *; img-src * data: blob:; font-src 'self' data:; media-src *; connect-src *
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] X-XSS-Protection: 1; mode=block
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] X-Content-Type-Options: nosniff
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] X-Frame-Options: Sameorigin
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] X-Robots-Tag: none
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] X-Download-Options: noopen
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] X-Permitted-Cross-Domain-Policies: none
21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] Content-type: text/html; charset in /mnt/web024/a2/74/12345678/htdocs/owncloud/updater/src/Utils/OccRunner.php on line 59
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] PHP Fatal error: Uncaught exception 'UnexpectedValueException' with message 'Could not parse a response for config:list --private. Please check if the current shell user can run occ command. Raw output:
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] X-Powered-By: PHP/5.6.22
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] Set-Cookie: ocenobfbc2kr=v31jombl1pjn85fu5efchgi616; path=/; HttpOnly
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] Expires: Thu, 19 Nov 1981 08:52:00 GMT
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] Pragma: no-cache
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] Set-Cookie: oc_sessionPassphrase=QIEBdz8SH4ySsOxxrbozEcEPNJfwTjDR2bcfJS51rbesyr6xk95cGM%2Fe2m1Ck8wiusylxTmOC6gRhzA0irnSi47rE2v8mM48LEWIvBAfBIalP24nzlEvr%2BI2rCEc3qvp; path=/; httponly
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] Content-Security-Policy:default-src 'self'; script-src 'self' 'unsafe-eval'; style-src 'self' 'unsafe-inline'; frame-src *; img-src * data: blob:; font-src 'self' data:; media-src *; connect-src *
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] X-XSS-Protection: 1; mode=block
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] X-Content-Type-Options: nosniff
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] X-Frame-Options: Sameorigin
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] X-Robots-Tag: none
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] X-Download-Options: noopen
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] X-Permitted-Cross-Domain-Policies: none
21.07.2016 16:56:30 abc.de [client xxx.xxx.xxx.xxx] Content-type: text/html; charset=UTF in /mnt/web024/a2/74/12345678/htdocs/owncloud/updater/src/Utils/OccRunner.php on line 59
"21.07.2016 16:56:29 abc.de [client xxx.xxx.xxx.xxx] Expires: Thu, 19 Nov 1981 08:52:00 GMT"
That's a tad past expiration date, one might think.
Is there a way to manually open the Updater? A link or s.th. like that?
