Just upgraded to Ubuntu 16.04LTS and then dealt with owncloud as well (using the integrated updater to 10.0.3) but it looks like something ended up in the stable repo that shouldn't have been there ?
Technical information
them.
Results
- core
- FILE_MISSING
- CHANGELOG.md
- updater/vendor/composer/autoload_static.php
- updater/vendor/symfony/console/Helper/ProgressIndicator.php
- updater/vendor/symfony/polyfill-mbstring/Mbstring.php
- updater/vendor/symfony/polyfill-mbstring/bootstrap.php
- updater/vendor/symfony/polyfill-mbstring/composer.json
- INVALID_HASH
- updater/README.md
- updater/app/bootstrap.php
- updater/app/config/container.php
- updater/pub/js/main.js
- updater/src/Command/BackupDataCommand.php
- updater/src/Command/BackupDbCommand.php
- updater/src/Command/CheckSystemCommand.php
- updater/src/Command/CheckpointCommand.php
- updater/src/Command/CleanCacheCommand.php
- updater/src/Command/Command.php
- updater/src/Command/DetectCommand.php
- updater/src/Command/ExecuteCoreUpgradeScriptsCommand.php
- updater/src/Command/InfoCommand.php
- updater/src/Command/MaintenanceModeCommand.php
- updater/src/Command/PostUpgradeCleanupCommand.php
- updater/src/Command/PostUpgradeRepairCommand.php
- updater/src/Command/PreUpgradeRepairCommand.php
- updater/src/Command/RestartWebServerCommand.php
- updater/src/Command/StartCommand.php
- updater/src/Command/UpdateConfigCommand.php
- updater/src/Console/Application.php
- updater/src/Controller/DownloadController.php
- updater/src/Controller/IndexController.php
- updater/src/Formatter/HtmlOutputFormatter.php
- updater/src/Http/Request.php
- updater/src/Resources/views/base.php
- updater/src/Resources/views/partials/inner.php
- updater/src/Resources/views/partials/login.php
- updater/src/Utils/AppManager.php
- updater/src/Utils/Checkpoint.php
- updater/src/Utils/Collection.php
- updater/src/Utils/ConfigReader.php
- updater/src/Utils/DocLink.php
- updater/src/Utils/Feed.php
- updater/src/Utils/Fetcher.php
- updater/src/Utils/FilesystemHelper.php
- updater/src/Utils/Locator.php
- updater/src/Utils/OccRunner.php
- updater/src/Utils/Registry.php
- updater/src/Utils/ZipExtractor.php
- updater/vendor/autoload.php
- updater/vendor/composer/autoload_files.php
- updater/vendor/composer/autoload_psr4.php
- updater/vendor/composer/autoload_real.php
- updater/vendor/composer/installed.json
- updater/vendor/paragonie/random_compat/CHANGELOG.md
- updater/vendor/paragonie/random_compat/ERRATA.md
- updater/vendor/paragonie/random_compat/lib/random.php
- updater/vendor/react/promise/CHANGELOG.md
- updater/vendor/react/promise/composer.json
- updater/vendor/react/promise/src/LazyPromise.php
- updater/vendor/react/promise/src/Promise.php
- updater/vendor/react/promise/src/functions.php
- updater/vendor/symfony/console/Application.php
- updater/vendor/symfony/console/CHANGELOG.md
- updater/vendor/symfony/console/Command/Command.php
- updater/vendor/symfony/console/Command/HelpCommand.php
- updater/vendor/symfony/console/Command/ListCommand.php
- updater/vendor/symfony/console/Descriptor/ApplicationDescription.php
- updater/vendor/symfony/console/Descriptor/Descriptor.php
- updater/vendor/symfony/console/Descriptor/MarkdownDescriptor.php
- updater/vendor/symfony/console/Descriptor/TextDescriptor.php
- updater/vendor/symfony/console/Formatter/OutputFormatter.php
- updater/vendor/symfony/console/Formatter/OutputFormatterStyleStack.php
- updater/vendor/symfony/console/Helper/DescriptorHelper.php
- updater/vendor/symfony/console/Helper/DialogHelper.php
- updater/vendor/symfony/console/Helper/Helper.php
- updater/vendor/symfony/console/Helper/HelperSet.php
- updater/vendor/symfony/console/Helper/ProgressBar.php
- updater/vendor/symfony/console/Helper/ProgressHelper.php
- updater/vendor/symfony/console/Helper/QuestionHelper.php
- updater/vendor/symfony/console/Helper/SymfonyQuestionHelper.php
- updater/vendor/symfony/console/Helper/Table.php
- updater/vendor/symfony/console/Helper/TableCell.php
- updater/vendor/symfony/console/Helper/TableHelper.php
- updater/vendor/symfony/console/Helper/TableStyle.php
- updater/vendor/symfony/console/Input/ArgvInput.php
- updater/vendor/symfony/console/Input/ArrayInput.php
- updater/vendor/symfony/console/Input/Input.php
- updater/vendor/symfony/console/Input/InputDefinition.php
- updater/vendor/symfony/console/Input/InputInterface.php
- updater/vendor/symfony/console/Input/StringInput.php
- updater/vendor/symfony/console/LICENSE
- updater/vendor/symfony/console/Output/ConsoleOutput.php
- updater/vendor/symfony/console/Output/OutputInterface.php
- updater/vendor/symfony/console/Question/ChoiceQuestion.php
- updater/vendor/symfony/console/Question/Question.php
- updater/vendor/symfony/console/Shell.php
- updater/vendor/symfony/console/Style/SymfonyStyle.php
- updater/vendor/symfony/console/Tester/ApplicationTester.php
- updater/vendor/symfony/console/Tester/CommandTester.php
- updater/vendor/symfony/console/composer.json
- updater/vendor/symfony/process/ExecutableFinder.php
- updater/vendor/symfony/process/PhpExecutableFinder.php
- updater/vendor/symfony/process/PhpProcess.php
- updater/vendor/symfony/process/Pipes/AbstractPipes.php
- updater/vendor/symfony/process/Pipes/PipesInterface.php
- updater/vendor/symfony/process/Pipes/UnixPipes.php
- updater/vendor/symfony/process/Pipes/WindowsPipes.php
- updater/vendor/symfony/process/Process.php
- updater/vendor/symfony/process/ProcessBuilder.php
- updater/vendor/symfony/process/ProcessUtils.php
- updater/vendor/symfony/process/composer.json
- updater/vendor/symfony/process/Exception/ProcessFailedException.php
- updater/vendor/symfony/process/phpunit.xml.dist
- updater/vendor/symfony/process/README.md
- updater/vendor/symfony/console/Output/Output.php
- updater/vendor/symfony/console/Output/NullOutput.php
- updater/vendor/symfony/console/Output/StreamOutput.php
- updater/vendor/symfony/console/Helper/TableSeparator.php
- updater/vendor/symfony/console/Input/InputOption.php
- updater/vendor/symfony/console/Input/InputArgument.php
- updater/vendor/symfony/console/Formatter/OutputFormatterStyle.php
- updater/vendor/symfony/console/phpunit.xml.dist
- updater/vendor/symfony/console/README.md
- updater/vendor/composer/LICENSE
- updater/vendor/composer/ClassLoader.php
- updater/vendor/react/promise/.travis.yml
- updater/vendor/react/promise/src/RejectedPromise.php
- updater/vendor/react/promise/src/UnhandledRejectionException.php
- updater/vendor/react/promise/src/FulfilledPromise.php
- updater/vendor/react/promise/LICENSE
- updater/vendor/react/promise/phpunit.xml.dist
- updater/vendor/react/promise/README.md
- EXTRA_FILE
- updater/composer.json
- updater/.travis.yml
- updater/src/Tests/Http/RequestTest.php
- updater/src/Tests/Controller/DownloadControllerTest.php
- updater/src/Tests/Utils/RegistryTest.php
- updater/src/Tests/Utils/CheckpointTest.php
- updater/src/Tests/Utils/OccRunnerTest.php
- updater/src/Tests/Utils/ConfigReaderTest.php
- updater/src/Tests/Utils/DocLinkTest.php
- updater/src/Tests/Utils/AppManagerTest.php
- updater/src/Tests/Utils/FetcherTest.php
- updater/src/Tests/Utils/FeedTest.php
- updater/src/Tests/StreamInterface.php
- updater/src/Tests/phpunit.xml
- updater/src/Tests/bootstrap.php
- updater/src/Command/EnableNotShippedAppsCommand.php
- updater/src/Command/DisableNotShippedAppsCommand.php
- updater/src/Command/DbUpgradeCommand.php
- updater/box.json
- updater/vendor/ircmaxell/password-compat/composer.json
- updater/vendor/ircmaxell/password-compat/lib/password.php
- updater/vendor/ircmaxell/password-compat/version-test.php
- updater/vendor/ircmaxell/password-compat/LICENSE.md
- updater/vendor/symfony/polyfill-php55/composer.json
- updater/vendor/symfony/polyfill-php55/Php55.php
- updater/vendor/symfony/polyfill-php55/README.md
- updater/vendor/symfony/polyfill-php55/Php55ArrayColumn.php
- updater/vendor/symfony/polyfill-php55/bootstrap.php
- updater/vendor/symfony/polyfill-util/composer.json
- updater/vendor/symfony/polyfill-util/BinaryNoFuncOverload.php
- updater/vendor/symfony/polyfill-util/BinaryOnFuncOverload.php
- updater/vendor/symfony/polyfill-util/README.md
- updater/vendor/symfony/polyfill-util/TestListener.php
- updater/vendor/symfony/polyfill-util/Binary.php
- updater/vendor/symfony/polyfill-php56/composer.json
- updater/vendor/symfony/polyfill-php56/Php56.php
- updater/vendor/symfony/polyfill-php56/README.md
- updater/vendor/symfony/polyfill-php56/bootstrap.php
- updater/CONTRIBUTING.md
- updater/composer.lock
- updater/nbproject/project.properties
- updater/nbproject/project.xml
- updater/.scrutinizer.yml
- FILE_MISSING
