yes, I’m very late
I have trouble updating my ownCloud.
Error and log attached.
Could you help here please?
Thanks a million!
Error message of updater (UI):
Update fehlgeschlagen.Unable to move /www/htdocs/PAGE/cloud.PAGE.de/_oc-upgrade/8.1.11/core/core to /www/htdocs/PAGE/cloud.PAGE.de/core
Log:
- opendir(/tmp): failed to open dir: Permission denied at /www/htdocs/PAGE/cloud.PAGE.de/lib/private/tempmanager.php#179
- Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set ‘always_populate_raw_post_data’ to ‘-1’ in php.ini and use the php://input stream instead. at Unknown#0
- rename(/www/htdocs/PAGE/cloud.PAGE.de/_oc-upgrade/8.1.11/core/core,/www/htdocs/PAGE/cloud.PAGE.de/core): Directory not empty at /www/htdocs/PAGE/cloud.PAGE.de/apps/updater/lib/helper.php#45
- in_array() expects parameter 2 to be array, null given at /www/htdocs/PAGE/cloud.PAGE.de/apps/updater/lib/location/core.php#35
- Undefined index: 8.1 at /www/htdocs/PAGE/cloud.PAGE.de/apps/updater/lib/location/core.php#26
- Success: 3rdparty
Beste, Tobi
