- Install and configure 10.2.0
- Update to 10.3.2 per manual_upgrade.html
- Error encountered during occ upgrade command
Successful update
- Chatter in update log about “App [app name] is not know at the marketplace”
- Exception thrown after updating database:
“An unhandled exception has been thrown:
Error: Class ‘OC_Mount_Config’ not found in /var/www/html/owncloud/apps/files_external/appinfo/app.php:34” - Unable to access owncloud web interface after disabling maintenance mode (webpage attempts to perform update and fails)
Ubuntu 18.04 LTS
Apache2
Mariadb
10.2.0
Updating from older version
Manual install from download.owncloud.org/community
Unable to log into web interface (see Actual Behavior)
“system”: {
“instanceid”: “oc48x9dsucr4”,
“trusted_domains”: [
“192.168.1.5”
“datadirectory”: “/mnt/Owncloud”,
“overwrite.cli.url”: “http://192.168.1.5/owncloud”,
“dbtype”: “mysql”,
“version”: “10.2.0.5”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“apps_paths”: [
“path”: “/var/www/html/owncloud/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/html/owncloud/apps-external”,
“url”: “/apps-external”,
“writable”: true
“installed”: true,
“maintenance”: true,
“loglevel”: 0,
“theme”: “”
Enabled:
- comments: 0.3.0
- configreport: 0.2.0
- dav: 0.4.0
- federatedfilesharing: 0.4.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_sharing: 0.11.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.10.1
- firstrunwizard: 1.2.0
- market: 0.5.0
- notifications: 0.5.0
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
Disabled: - encryption
- external
- files_mediaviewer
- user_external
cifs
Are you using encryption:
No
No
Firefox
Windows 10
[Sat Feb 15 00:07:27.125222 2020] [mpm_prefork:notice] [pid 22223] AH00163: Apache/2.4.29 (Ubuntu) configured – resuming normal operations
[Sat Feb 15 00:07:27.125254 2020] [core:notice] [pid 22223] AH00094: Command line: ‘/usr/sbin/apache2’
[unrelated messages from another process]
[Sat Feb 15 13:25:57.708730 2020] [mpm_prefork:notice] [pid 22223] AH00169: caught SIGTERM, shutting down
[Sat Feb 15 13:42:15.426852 2020] [mpm_prefork:notice] [pid 20720] AH00163: Apache/2.4.29 (Ubuntu) configured – resuming normal operations
[Sat Feb 15 13:42:15.427104 2020] [core:notice] [pid 20720] AH00094: Command line: ‘/usr/sbin/apache2’
{“reqId”:“SPiQhkqsnbtZJKUqeFCL”,“level”:0,“time”:“2020-02-15T20:37:26+00:00”,“remoteAddr”:"",“user”:"–",“app”:“core”,“method”:"–",“url”:"–",“message”:“starting upgrade from 10.2.0.5 to 10.3.2.2”}
{“reqId”:“SPiQhkqsnbtZJKUqeFCL”,“level”:3,“time”:“2020-02-15T20:37:27+00:00”,“remoteAddr”:"",“user”:"–",“app”:“core”,“method”:"–",“url”:"–",“message”:“Exception: {“Exception”:“OC\\RepairException”,“Message”:“Upgrade is not possible”,“Code”:0,“Trace”:”#0 \/var\/www\/html\/owncloud\/lib\/private\/Repair.php(90): OC\\Repair\\Apps->run(Object(OC\\Repair))\n#1 \/var\/www\/html\/owncloud\/lib\/private\/Updater.php(219): OC\\Repair->run()\n#2 \/var\/www\/html\/owncloud\/lib\/private\/Updater.php(111): OC\\Updater->checkAppsCompatibility()\n#3 \/var\/www\/html\/owncloud\/core\/Command\/Upgrade.php(261): OC\\Updater->upgrade()\n#4 \/var\/www\/html\/owncloud\/lib\/composer\/symfony\/console\/Command\/Command.php(255): OC\\Core\\Command\\Upgrade->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#5 \/var\/www\/html\/owncloud\/lib\/composer\/symfony\/console\/Application.php(982): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#6 \/var\/www\/html\/owncloud\/lib\/composer\/symfony\/console\/Application.php(255): Symfony\\Component\\Console\\Application->doRunCommand(Object(OC\\Core\\Command\\Upgrade), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#7 \/var\/www\/html\/owncloud\/lib\/composer\/symfony\/console\/Application.php(148): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#8 \/var\/www\/html\/owncloud\/lib\/private\/Console\/Application.php(165): Symfony\\Component\\Console\\Application->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#9 \/var\/www\/html\/owncloud\/console.php(106): OC\\Console\\Application->run()\n#10 \/var\/www\/html\/owncloud\/occ(11): require_once(’\/var\/www\/html\/o…’)\n#11 {main}",“File”:"\/var\/www\/html\/owncloud\/lib\/private\/Repair\/Apps.php",“Line”:219}"}
{“reqId”:“coP3TREVub7t7T0DD5Ml”,“level”:0,“time”:“2020-02-15T20:40:29+00:00”,“remoteAddr”:"",“user”:"–",“app”:“core”,“method”:"–",“url”:"–",“message”:“starting upgrade from 10.2.0.5 to 10.3.2.2”}
{“reqId”:“Zi43fQ689Hth1GlqkMeR”,“level”:3,“time”:“2020-02-15T20:42:19+00:00”,“remoteAddr”:“192.168.1.3”,“user”:"–",“app”:“index”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=5335bec3f4f30450e913610f3a9e607f",“message”:“Exception: {“Exception”:“Error”,“Message”:“Class ‘OC_Mount_Config’ not found”,“Code”:0,“Trace”:”#0 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(239): require_once()\n#1 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(190): OC_App::requireAppFile(‘files_external’)\n#2 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(124): OC_App::loadApp(‘files_external’)\n#3 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php(147): OC_App::loadApps(Array)\n#4 \/var\/www\/html\/owncloud\/lib\/base.php(919): OC_Util::setupFS()\n#5 \/var\/www\/html\/owncloud\/index.php(54): OC::handleRequest()\n#6 {main}",“File”:"\/var\/www\/html\/owncloud\/apps\/files_external\/appinfo\/app.php",“Line”:34}"}
{“reqId”:“wLHF73VpsJIkY4NKFwsk”,“level”:0,“time”:“2020-02-15T20:42:35+00:00”,“remoteAddr”:“192.168.1.3”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/owncloud/core/ajax/update.php?requesttoken=OiQ7IhwXAlY9Gz9cKQtRdFUiSR0WUzJqOys1JTY8MEY%3D%3AwaKaMnV9dPSikC938V8jc4zRsjeSOZf%2BF2Zvl755AZo%3D",“message”:“starting upgrade from 10.2.0.5 to 10.3.2.2”}
{“reqId”:“wLHF73VpsJIkY4NKFwsk”,“level”:3,“time”:“2020-02-15T20:42:39+00:00”,“remoteAddr”:“192.168.1.3”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/core/ajax/update.php?requesttoken=OiQ7IhwXAlY9Gz9cKQtRdFUiSR0WUzJqOys1JTY8MEY%3D%3AwaKaMnV9dPSikC938V8jc4zRsjeSOZf%2BF2Zvl755AZo%3D",“message”:“Error: Class ‘OC_Mount_Config’ not found at /var/www/html/owncloud/apps/files_external/appinfo/app.php#34”}
{“reqId”:“s1vw2KDvD0spaQ0Fkw8X”,“level”:0,“time”:“2020-02-15T20:45:40+00:00”,“remoteAddr”:"",“user”:"–",“app”:“core”,“method”:"–",“url”:"–",“message”:“starting upgrade from 10.2.0.5 to 10.3.2.2”}
{“reqId”:“7NuflGuMMtNNjjYLcIXg”,“level”:0,“time”:“2020-02-15T20:53:02+00:00”,“remoteAddr”:"",“user”:"–",“app”:“core”,“method”:"–",“url”:"–",“message”:“starting upgrade from 10.2.0.5 to 10.3.2.2”}
{“reqId”:“Mz0PiURChhegCxBM2v77”,“level”:0,“time”:“2020-02-15T20:57:37+00:00”,“remoteAddr”:"",“user”:"–",“app”:“core”,“method”:"–",“url”:"–",“message”:“starting upgrade from 10.2.0.5 to 10.3.2.2”}
{“reqId”:“GSNH9G0LhfJW3Z7HXztw”,“level”:0,“time”:“2020-02-15T21:03:14+00:00”,“remoteAddr”:"",“user”:"–",“app”:“core”,“method”:"–",“url”:"–",“message”:“starting upgrade from 10.2.0.5 to 10.3.2.2”}
{“reqId”:“L1kwsgjRTVU03JNo6e3h”,“level”:0,“time”:“2020-02-15T21:05:03+00:00”,“remoteAddr”:"",“user”:"–",“app”:“core”,“method”:"–",“url”:"–",“message”:“starting upgrade from 10.2.0.5 to 10.3.2.2”}
{“reqId”:“cILVr4XMkUXYfBQ4ZwwM”,“level”:3,“time”:“2020-02-15T21:09:29+00:00”,“remoteAddr”:“192.168.1.3”,“user”:"–",“app”:“index”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=5335bec3f4f30450e913610f3a9e607f",“message”:“Exception: {“Exception”:“Error”,“Message”:“Class ‘OC_Mount_Config’ not found”,“Code”:0,“Trace”:”#0 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(239): require_once()\n#1 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(190): OC_App::requireAppFile(‘files_external’)\n#2 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(124): OC_App::loadApp(‘files_external’)\n#3 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php(147): OC_App::loadApps(Array)\n#4 \/var\/www\/html\/owncloud\/lib\/base.php(919): OC_Util::setupFS()\n#5 \/var\/www\/html\/owncloud\/index.php(54): OC::handleRequest()\n#6 {main}",“File”:"\/var\/www\/html\/owncloud\/apps\/files_external\/appinfo\/app.php",“Line”:34}"}
{“reqId”:“V7FnJB7B7jQPJaaqCmnu”,“level”:0,“time”:“2020-02-15T21:09:36+00:00”,“remoteAddr”:“192.168.1.3”,“user”:"–",“app”:“core”,“method”:“GET”,“url”:"/owncloud/core/ajax/update.php?requesttoken=KS01IDYfDi0IOSplDSsvFA9MJTEfLR1qenIXEjYeZwc%3D%3AdhEcgfZBQrFPOcGSb8TFjJUR23GdOx1jXgB4gL%2Fnexg%3D",“message”:“starting upgrade from 10.2.0.5 to 10.3.2.2”}
{“reqId”:“V7FnJB7B7jQPJaaqCmnu”,“level”:3,“time”:“2020-02-15T21:09:39+00:00”,“remoteAddr”:“192.168.1.3”,“user”:"–",“app”:“PHP”,“method”:“GET”,“url”:"/owncloud/core/ajax/update.php?requesttoken=KS01IDYfDi0IOSplDSsvFA9MJTEfLR1qenIXEjYeZwc%3D%3AdhEcgfZBQrFPOcGSb8TFjJUR23GdOx1jXgB4gL%2Fnexg%3D",“message”:“Error: Class ‘OC_Mount_Config’ not found at /var/www/html/owncloud/apps/files_external/appinfo/app.php#34”}
{“reqId”:“j9t8ePq6hvCufjpcwS2o”,“level”:3,“time”:“2020-02-15T21:17:05+00:00”,“remoteAddr”:“192.168.1.3”,“user”:"–",“app”:“index”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=5335bec3f4f30450e913610f3a9e607f",“message”:“Exception: {“Exception”:“Error”,“Message”:“Class ‘OC_Mount_Config’ not found”,“Code”:0,“Trace”:”#0 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(239): require_once()\n#1 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(190): OC_App::requireAppFile(‘files_external’)\n#2 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(124): OC_App::loadApp(‘files_external’)\n#3 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php(147): OC_App::loadApps(Array)\n#4 \/var\/www\/html\/owncloud\/lib\/base.php(919): OC_Util::setupFS()\n#5 \/var\/www\/html\/owncloud\/index.php(54): OC::handleRequest()\n#6 {main}",“File”:"\/var\/www\/html\/owncloud\/apps\/files_external\/appinfo\/app.php",“Line”:34}"}
{“reqId”:“zo373fR3Dgb4nOJqBsiD”,“level”:3,“time”:“2020-02-15T21:17:05+00:00”,“remoteAddr”:“192.168.1.3”,“user”:"–",“app”:“index”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=5335bec3f4f30450e913610f3a9e607f",“message”:“Exception: {“Exception”:“Error”,“Message”:“Class ‘OC_Mount_Config’ not found”,“Code”:0,“Trace”:”#0 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(239): require_once()\n#1 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(190): OC_App::requireAppFile(‘files_external’)\n#2 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(124): OC_App::loadApp(‘files_external’)\n#3 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php(147): OC_App::loadApps(Array)\n#4 \/var\/www\/html\/owncloud\/lib\/base.php(919): OC_Util::setupFS()\n#5 \/var\/www\/html\/owncloud\/index.php(54): OC::handleRequest()\n#6 {main}",“File”:"\/var\/www\/html\/owncloud\/apps\/files_external\/appinfo\/app.php",“Line”:34}"}
{“reqId”:“2tHGccrtEo4CpNnUgia7”,“level”:3,“time”:“2020-02-15T21:17:13+00:00”,“remoteAddr”:“192.168.1.3”,“user”:"–",“app”:“index”,“method”:“GET”,“url”:"/owncloud/index.php/core/js/oc.js?v=5335bec3f4f30450e913610f3a9e607f",“message”:“Exception: {“Exception”:“Error”,“Message”:“Class ‘OC_Mount_Config’ not found”,“Code”:0,“Trace”:”#0 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(239): require_once()\n#1 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(190): OC_App::requireAppFile(‘files_external’)\n#2 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/app.php(124): OC_App::loadApp(‘files_external’)\n#3 \/var\/www\/html\/owncloud\/lib\/private\/legacy\/util.php(147): OC_App::loadApps(Array)\n#4 \/var\/www\/html\/owncloud\/lib\/base.php(919): OC_Util::setupFS()\n#5 \/var\/www\/html\/owncloud\/index.php(54): OC::handleRequest()\n#6 {main}",“File”:"\/var\/www\/html\/owncloud\/apps\/files_external\/appinfo\/app.php",“Line”:34}"}
{“reqId”:“6s2fiBDc6eXxk9dpJazB”,“level”:0,“time”:“2020-02-15T21:17:43+00:00”,“remoteAddr”:"",“user”:"–",“app”:“core”,“method”:"–",“url”:"–",“message”:“starting upgrade from 10.2.0.5 to 10.3.2.2”}
No such log
