Upgrade 10.4.0.4 to 10.4.1 - cli updater not working
  1. sudo -u www-data php occ updater/application.php
update version of owncloud
error:
Command “updater/application.php” is not defined.
Ubuntu server 18.04.4
Apache
Mysql
10.4.0.4
updated
owncloud server - community edition
none found
    "system": {
        "instanceid": "occi9f4y0ija",
        "trusted_domains": [
            "192.168.25.71",
            "ocx.myplanet-intra.com"
        "overwrite.cli.url": "https:\/\/192.168.25.71",
        "dbtype": "mysql",
        "version": "10.4.0.4",
        "dbname": "oc",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "logtimezone": "UTC",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/apps-external",
                "writable": true
        "installed": true,
        "redis": {
            "host": "localhost",
            "port": 6379
        "loglevel": 0,
        "mail_smtpmode": "smtp",
        "mail_smtpport": "25",
        "maintenance": false,
        "enable_certificate_management": true,
        "updater.secret": "***REMOVED SENSITIVE VALUE***"
```Enabled:
  - comments: 0.3.0
  - configreport: 0.2.0
  - dav: 0.5.0
  - federatedfilesharing: 0.5.0
  - federation: 0.1.0
  - files: 1.5.2
  - files_external: 0.7.1
  - files_mediaviewer: 1.0.1
  - files_sharing: 0.12.0
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - firstrunwizard: 1.2.0
  - market: 0.5.0
  - notifications: 0.5.0
  - provisioning_api: 0.5.0
  - systemtags: 0.3.0
  - updatenotification: 0.2.1
Disabled:
  - encryption
  - external
  - user_external
no
no
no
SELECT * FROM oc_appconfig WHERE appid = ‘user_ldap’;
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
c) …
if i’m looking at this list i can’t see that the Updater app is installed. If the app is not installed then i think the cli updater command isn’t available at all.
According to the docs https://doc.owncloud.com/server/admin_manual/maintenance/manual_upgrade.html the upgrade command is
sudo -u www-data php occ upgrade
The updater is core functionality and doesn’t require any app.
ah this is really good to know. I always thought that GitHub - owncloud/updater is a separate app because it is also called like this at the following link: :frowning_face:
https://doc.owncloud.com/server/10.4/admin_manual/maintenance/update.html
There the previously mentioned updater/application.php command is listed, maybe that documentation is outdated?
https://doc.owncloud.com/server/10.4/admin_manual/maintenance/update.html#command-line-options
The preferred variant for upgrades is occ upgrade, which is a core functionality.
With the command provided by the OP the web updater upgrade script is called, which (1) only works, if the app is installed and (2) may break on bigger ownCloud setups.
The docs probably should point out this as well.
indeed occ upgrade is what i’m using as well after updating the ownCloud code base and using the mentioned updater/application.php seems like a different use case to me.
