- yum upgrade to current version 9.1.1.3 from repository
- sudo -u apache php occ upgrade
Get usable current version
Set log level to debug
Checking whether the database schema can be updated (this can take a long time depending on the database size)
Done
24/24 [============================] 100%
Checked database schema update
Checking updates of apps
Checked database schema update for apps
Updating database schema
Updated database
Drop old database tables
Done
28/28 [============================] 100%
Remove old (< 9.0) calendar/contact shares
Done
4/4 [============================] 100%
Fix permissions so avatars can be stored again
Done
2/2 [============================] 100%
Remove shares of a users root folder
Starting ...
16/1286 [>---------------------------] 1% An unhandled exception has been thrown:
Error: Class 'OCA\FederatedFileSharing\DiscoveryManager' not found in /var/www/html/owncloud/apps/files_sharing/lib/AppInfo/Application.php:83
Stack trace:
#0 /var/www/html/owncloud/3rdparty/pimple/pimple/src/Pimple/Container.php(113): OCA\Files_Sharing\AppInfo\Application->OCA\Files_Sharing\AppInfo\{closure}(Object(OC\AppFramework\DependencyInjection\DIContainer))
#1 /var/www/html/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(102): Pimple\Container->offsetGet('ExternalManager')
#2 /var/www/html/owncloud/apps/files_sharing/lib/AppInfo/Application.php(129): OC\AppFramework\Utility\SimpleContainer->query('ExternalManager')
#3 /var/www/html/owncloud/apps/files_sharing/lib/External/MountProvider.php(53): OCA\Files_Sharing\AppInfo\Application->OCA\Files_Sharing\AppInfo\{closure}()
#4 /var/www/html/owncloud/apps/files_sharing/lib/External/MountProvider.php(72): OCA\Files_Sharing\External\MountProvider->getMount(Object(OC\User\User), Array, Object(OC\Files\Storage\StorageFactory))
#5 /var/www/html/owncloud/lib/private/Files/Config/MountProviderCollection.php(76): OCA\Files_Sharing\External\MountProvider->getMountsForUser(Object(OC\User\User), Object(OC\Files\Storage\StorageFactory))
#6 [internal function]: OC\Files\Config\MountProviderCollection->OC\Files\Config\{closure}(Object(OCA\Files_Sharing\External\MountProvider))
#7 /var/www/html/owncloud/lib/private/Files/Config/MountProviderCollection.php(77): array_map(Object(Closure), Array)
#8 /var/www/html/owncloud/lib/private/Files/Filesystem.php(422): OC\Files\Config\MountProviderCollection->getMountsForUser(Object(OC\User\User))
#9 /var/www/html/owncloud/apps/files_sharing/lib/sharedstorage.php(99): OC\Files\Filesystem::initMountPoints('1B5F76F8-14BB-4...')
#10 /var/www/html/owncloud/apps/files_sharing/lib/sharedstorage.php(448): OC\Files\Storage\Shared->init()
#11 /var/www/html/owncloud/lib/private/Files/Storage/Wrapper/Wrapper.php(485): OC\Files\Storage\Shared->getWrapperStorage()
#12 /var/www/html/owncloud/apps/files_sharing/lib/sharedstorage.php(122): OC\Files\Storage\Wrapper\Wrapper->instanceOfStorage('\\OC\\Files\\Stora...')
#13 /var/www/html/owncloud/lib/private/legacy/util.php(148): OC\Files\Storage\Shared->instanceOfStorage('\\OC\\Files\\Stora...')
#14 /var/www/html/owncloud/lib/private/Files/Storage/StorageFactory.php(100): OC_Util::{closure}('/C71A1E70-A414-...', Object(OC\Files\Storage\Shared), Object(OCA\Files_Sharing\SharedMount))
#15 /var/www/html/owncloud/lib/private/Files/Storage/StorageFactory.php(82): OC\Files\Storage\StorageFactory->wrap(Object(OCA\Files_Sharing\SharedMount), Object(OC\Files\Storage\Shared))
#16 /var/www/html/owncloud/lib/private/Files/Mount/MountPoint.php(137): OC\Files\Storage\StorageFactory->getInstance(Object(OCA\Files_Sharing\SharedMount), '\\OC\\Files\\Stora...', Array)
#17 /var/www/html/owncloud/lib/private/Files/Mount/MountPoint.php(160): OC\Files\Mount\MountPoint->createStorage()
#18 /var/www/html/owncloud/lib/private/Files/View.php(1356): OC\Files\Mount\MountPoint->getStorage()
#19 /var/www/html/owncloud/lib/private/Files/Node/Root.php(180): OC\Files\View->getFileInfo('/C71A1E70-A414-...')
#20 /var/www/html/owncloud/lib/private/Files/Node/Root.php(342): OC\Files\Node\Root->get('/C71A1E70-A414-...')
#21 [internal function]: OC\Files\Node\Root->getUserFolder('C71A1E70-A414-4...')
#22 /var/www/html/owncloud/lib/private/Files/Node/LazyRoot.php(64): call_user_func_array(Array, Array)
#23 /var/www/html/owncloud/lib/private/Files/Node/LazyRoot.php(281): OC\Files\Node\LazyRoot->__call('getUserFolder', Array)
#24 /var/www/html/owncloud/lib/private/Repair/RemoveRootShares.php(82): OC\Files\Node\LazyRoot->getUserFolder('C71A1E70-A414-4...')
#25 /var/www/html/owncloud/lib/private/User/Manager.php(359): OC\Repair\RemoveRootShares->OC\Repair\{closure}(Object(OC\User\User))
#26 /var/www/html/owncloud/lib/private/Repair/RemoveRootShares.php(101): OC\User\Manager->callForAllUsers(Object(Closure))
#27 /var/www/html/owncloud/lib/private/Repair/RemoveRootShares.php(73): OC\Repair\RemoveRootShares->removeRootShares(Object(OC\Repair))
#28 /var/www/html/owncloud/lib/private/Repair.php(88): OC\Repair\RemoveRootShares->run(Object(OC\Repair))
#29 /var/www/html/owncloud/lib/private/Updater.php(267): OC\Repair->run()
#30 /var/www/html/owncloud/lib/private/Updater.php(150): OC\Updater->doUpgrade('9.1.1.3', '9.0.3.2')
#31 /var/www/html/owncloud/core/Command/Upgrade.php(290): OC\Updater->upgrade()
#32 /var/www/html/owncloud/3rdparty/symfony/console/Command/Command.php(259): OC\Core\Command\Upgrade->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#33 /var/www/html/owncloud/3rdparty/symfony/console/Application.php(844): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#34 /var/www/html/owncloud/3rdparty/symfony/console/Application.php(192): Symfony\Component\Console\Application->doRunCommand(Object(OC\Core\Command\Upgrade), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#35 /var/www/html/owncloud/3rdparty/symfony/console/Application.php(123): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#36 /var/www/html/owncloud/lib/private/Console/Application.php(146): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#37 /var/www/html/owncloud/console.php(94): OC\Console\Application->run()
#38 /var/www/html/owncloud/occ(11): require_once('/var/www/html/o...')
#39 {main}[
Operating system: CentOS Linux release 7.2.1511
Web server: Apache/2.4.6 (CentOS)
Database: mysql Ver 15.1 Distrib 5.5.50-MariaDB, for Linux (x86_64) using readline 5.1
PHP version: PHP 7.0.11
ownCloud version (see ownCloud admin page): 9.0.3.2 → 9.1.1.3
Updated from an older ownCloud or fresh install: upgrade
ownCloud log (data/owncloud.log, see How to find webserver or OC logfile / enable php logfile): no information provided
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): LDAP
