When running the upgrade to 10.0.2 I get errors and update wasn't succesfull:
Any tips?
Paste of the log: Reparatiewaarschuwing:Exception Reparatiewaarschuwing:Archiefbestanden van type application/octet-stream niet ondersteund Reparatiewaarschuwing:Exception Reparatiewaarschuwing:Archiefbestanden van type application/octet-stream niet ondersteund Reparatiewaarschuwing:Exception Reparatiewaarschuwing:Archiefbestanden van type application/octet-stream niet ondersteund Reparatiewaarschuwing:Exception Reparatiewaarschuwing:Archiefbestanden van type application/octet-stream niet ondersteund Reparatiewaarschuwing:Exception Reparatiewaarschuwing:Archiefbestanden van type application/octet-stream niet ondersteund Reparatiewaarschuwing:Exception Reparatiewaarschuwing:Archiefbestanden van type application/octet-stream niet ondersteund Reparatiewaarschuwing:You have incompatible or missing apps enabled that could not be found or updated via the marketplace. Reparatiewaarschuwing:please install app manually with tarball or disable them with: occ app:disable activity occ app:disable calendar occ app:disable files_pdfviewer occ app:disable files_texteditor occ app:disable gallery
Well, the log message already says pretty clear what the error is: you have to disable the activity, calendar, files_pdfviewer, files_texteditor and gallery apps. This is because those apps are now made available on https://marketplace.owncloud.com/.
After disabling those apps by using the occ app:disable command the upgrade process should go through successfully.
Thx for your quick response. I have no access to CLI, so I used phpmyadmin to disable the plugins.
OC 10 indeed finished upgrade. I then went to the marketplace, to install new version of Calendar. I got the same error: Archiefbestanden van type application/octet-stream niet ondersteund.
I then tried update the Marketplace app itself. Same error.
Is this something I can fix myself? Or can you explain what I need to ask my hoster.
Hmm I am not sure to be honest. Do you have the PHP module zip installed ? Depending on the distribution this can have different names. For instance on Ubuntu 16.04 running the default PHP version, this is called php7.0-zip.
In cPanel I selected PHP 7 (although not the issue, I thought why not) and could then set some options for PHP. The error log complained about: method":"REPORT","url":"\/bestanden\/remote.php\/dav\/calendars\/bla\/personal\/","message":"You are using a fallback implementation of the intl extension. Installing the native one is highly recommended instead.
So I checked if the 'intl' extension was set. It wasn't so I enabled intl and could update flawlessly.
