I’m trying to upgrade from version 8.04
I’m running on a centos 7.5 with nginx
I was able to upgrade from 8.04 to 8.016 and to 8.1.12
but from 8.1.12 to 8.2.11 I always get this error:
Exception: Updates between multiple major versions and downgrades are unsupported.
Update failed
Any help?
José
