- NONE
Upgrade from Repository should upgrade to the next step
Actual behavior
Upgraded and bypassed 8.2 and caused issue (known issue if skipping version)
Ubuntu 16.04 LTS
Apache
MYSQL
Was 8.1 and upgraded to 9.0
Upgraded
Repository
Don’t know, can’t log in
$CONFIG = array (
‘instanceid’ => ‘ocwtuqcb1nwb’,
‘passwordsalt’ => ‘’,
‘secret’ => ‘’,
‘trusted_domains’ =>
array (
0 => ‘192.168.63.36’,
1 => ‘96.69.223.209’,
2 => ‘96.69.223.210’,
3 => ‘96.69.223.211’,
4 => ‘96.69.223.212’,
5 => ‘96.69.223.213’,
‘datadirectory’ => ‘/var/www/owncloud/data’,
‘overwrite.cli.url’ => ‘http://192.168.63.36/owncloud’,
‘dbtype’ => ‘mysql’,
‘version’ => ‘8.1.3.0’,
‘dbname’ => ‘owncloud’,
‘dbhost’ => ‘localhost’,
‘dbtableprefix’ => ‘oc_’,
‘dbuser’ => ‘oc_jdeherrera’,
‘dbpassword’ => ‘’,
‘installed’ => true,
‘maintenance’ => true,
‘updatechecker’ => false,
‘theme’ => ‘’,
‘loglevel’ => 2,
NO
NO
NO
NO
NO, says "Could not open imput file: occ"
Chrome
Windows 10 Pro
