Dear friends
My hosting server migrated to a new surrounding, now with support for newer php versions. Until now I run Owncloud 8.2.7 with php 5.6. (Ugly thing: the admin section tells me that I am running 9.0.11 (stable)).
Anyways: I tried to upgrade to 9.1.8 as suggested by owncloud after logging in as admin. I changed php to 7.x and upgraded. --> Error, nothing works. And I cant downgrade again… I still have my config, but it doesn’t work when I put it in the owncloud directory.
Here are the latest log entries:
Error PHP is_readable(): open_basedir restriction in effect. File(/dev/urandom) is not within the allowed path(s): (/home/ch36924/web/files:/home/ch36924/web/owncloud.homepage.ch/public_html:/home/ch36924/web/owncloud.homepage.ch/software_data:/home/ch36924/tmp) at /home/ch36924/web/owncloud.homepage.ch/public_html/3rdparty/paragonie/random_compat/lib/random.php#66 2020-10-21T18:39:19+00:00
Error PHP require_once(): Failed opening required ‘/home/ch36924/web/owncloud.homepage.ch/public_html/apps/files/appinfo/remote.php’ (include_path=’/home/ch36924/web/owncloud.homepage.ch/public_html/3rdparty/pear/console_getopt:/home/ch36924/web/owncloud.homepage.ch/public_html/3rdparty/pear/pear_exception:/home/ch36924/web/owncloud.homepage.ch/public_html/3rdparty/pear/pear-core-minimal/src:/home/ch36924/web/owncloud.homepage.ch/public_html/3rdparty/pear/archive_tar:/home/ch36924/web/owncloud.homepage.ch/public_html/3rdparty/phpseclib/phpseclib/phpseclib:/home/ch36924/web/owncloud.homepage.ch/public_html/lib/private:/home/ch36924/web/owncloud.homepage.ch/public_html/config:/home/ch36924/web/owncloud.homepage.ch/public_html/3rdparty:/home/ch36924/web/owncloud.homepage.ch/public_html/apps:.:/usr/share/php:/home/ch36924/web/owncloud.homepage.ch/public_html’) at /home/ch36924/web/owncloud.homepage.ch/public_html/remote.php#138 2020-10-21T18:39:19+00:00
Error PHP is_readable(): open_basedir restriction in effect. File(/dev/urandom) is not within the allowed path(s): (/home/ch36924/web/files:/home/ch36924/web/owncloud.homepage.ch/public_html:/home/ch36924/web/owncloud.homepage.ch/software_data:/home/ch36924/tmp) at /home/ch36924/web/owncloud.homepage.ch/public_html/3rdparty/paragonie/random_compat/lib/random.php#66 2020-10-21T18:40:57+00:00
Error PHP is_readable(): open_basedir restriction in effect. File(/dev/urandom) is not within the allowed path(s): (/home/ch36924/web/files:/home/ch36924/web/owncloud.homepage.ch/public_html:/home/ch36924/web/owncloud.homepage.ch/software_data:/home/ch36924/tmp) at /home/ch36924/web/owncloud.homepage.ch/public_html/3rdparty/paragonie/random_compat/lib/random.php#66 2020-10-21T18:40:32+00:00
On top of the admin page, theses warnings appear (sorry, in german):
Sicherheits- & Einrichtungswarnungen
Dein Webserver ist noch nicht hinreichend für Datei-Synchronisation konfiguriert, weil die WebDAV-Schnittstelle vermutlich defekt ist.
Einige Dateien haben die Integritätsprüfung nicht bestanden. Weiterführende Information findest Du in unserer Dokumentation. (Liste der ungültigen Dateien … / Erneut analysieren…)
PHP hat keine Leserechte auf /dev/urandom wovon aus Sicherheitsgründen höchst abzuraten ist. Weitere Informationen sind in der Dokumentation zu finden.
Du greifst auf diese Site über HTTP zu. Wir raten dringend dazu, Deinen Server so zu konfigurieren, dass er stattdessen nur HTTPS akzeptiert, wie es in unseren Sicherheitshinweisen beschrieben ist.
Es wurde kein Memory Cache konfiguriert. Um die Leistung zu verbessern, konfiguriere bitte einen Cache-Speicher, sofern vorhanden. Weitere Informationen findest du in unserer Dokumentation.
Bitte überprüfe noch einmal die Installationsanleitungen
und kontrolliere das Log auf mögliche Fehler oder Warnungen.
Any idea how to fix my installation?
Thanks a lot!
Patrick
