Upgrade from 9.1.6.2 to 10.0.2.1 fails with "Exception: market can't be enabled since it is not installed."
I’m really unhappy that RPMs are still only available for 9.1.6 , although 10.x is out for a while now.
So I tried to perform a manual upgrade from 9.1.6 to current 10.0.2.1, which failes :frowning:
  1. Download OC 10.0.2.1 and extract to empty “owncloud” folder
    (1b. Uninstall RPMs for 9.1.6.2)
  2. copy back “apps” and “data” from backup’ed 9.1.6.2 folder
  3. run sudo -u <oc_user> php occ upgrade
OC should be upgraded to 10.0.2.1
Set log level to debug
Exception: market can’t be enabled since it is not installed.
Update failed
Maintenance mode is kept active
Reset log level
OpenSuse 42.3
Apache 2.4.23
MariaDB 10.0.31
9.1.6.2
updated, started with 8.x
from rpms on http://download.owncloud.org/download/repositories/stable/openSUSE_Leap_42.3
“system”: {
“updatechecker”: false,
“instanceid”: “ocv90mja2d89”,
“trusted_domains”: [
“localhost:10080”,
“datadirectory”: “/srv/www/htdocs/owncloud/data”,
“overwrite.cli.url”: “http://localhost:10080/owncloud”,
“dbtype”: “mysql”,
“version”: “9.1.6.2”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“mail_smtpmode”: “sendmail”,
“mail_smtpsecure”: “tls”,
“mail_from_address”: “cloud”,
“maintenance”: true,
“theme”: “”,
“loglevel”: 0
Enabled:
Disabled:
  • calendar
  • contacts
  • tasks
no
yes
no
Firefox, always current
several
NO logs in apache’s erro log
{“reqId”:“Q3L10gRVIwqFjvsSJSBQ”,“level”:0,“time”:“2017-09-13T05:00:10+00:00”,“remoteAddr”:“”,“user”:“–”,“app”:“core”,“method”:“–”,“url”:“–”,“message”:“starting upgrade from 9.1.6.2 to 10.0.2.1”}
{“reqId”:“Q3L10gRVIwqFjvsSJSBQ”,“level”:3,“time”:“2017-09-13T05:00:10+00:00”,“remoteAddr”:“”,“user”:“–”,“app”:“core”,“method”:“–”,“url”:“–”,“message”:“Exception: {"Exception":"Exception","Message":"market can’t be enabled since it is not installed.","Code":0,"Trace":"#0 \/srv\/www\/htdocs\/owncloud\/lib\/private\/Repair\/Apps.php(119): OC\\App\\AppManager->enableApp(‘market’)\n#1 \/srv\/www\/htdocs\/owncloud\/lib\/private\/Repair.php(88): OC\\Repair\\Apps->run(Object(OC\\Repair))\n#2 \/srv\/www\/htdocs\/owncloud\/lib\/private\/Updater.php(221): OC\\Repair->run()\n#3 \/srv\/www\/htdocs\/owncloud\/lib\/private\/Updater.php(108): OC\\Updater->doUpgrade(‘10.0.2.1’, ‘9.1.6.2’)\n#4 \/srv\/www\/htdocs\/owncloud\/core\/Command\/Upgrade.php(249): OC\\Updater->upgrade()\n#5 \/srv\/www\/htdocs\/owncloud\/lib\/composer\/symfony\/console\/Command\/Command.php(262): OC\\Core\\Command\\Upgrade->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#6 \/srv\/www\/htdocs\/owncloud\/lib\/composer\/symfony\/console\/Application.php(826): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#7 \/srv\/www\/htdocs\/owncloud\/lib\/composer\/symfony\/console\/Application.php(189): Symfony\\Component\\Console\\Application->doRunCommand(Object(OC\\Core\\Command\\Upgrade), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#8 \/srv\/www\/htdocs\/owncloud\/lib\/composer\/symfony\/console\/Application.php(120): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#9 \/srv\/www\/htdocs\/owncloud\/lib\/private\/Console\/Application.php(160): Symfony\\Component\\Console\\Application->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#10 \/srv\/www\/htdocs\/owncloud\/console.php(99): OC\\Console\\Application->run()\n#11 \/srv\/www\/htdocs\/owncloud\/occ(11): require_once(‘\/srv\/www\/htdocs…’)\n#12 {main}","File":"\/srv\/www\/htdocs\/owncloud\/lib\/private\/App\/AppManager.php","Line":218}”}
out of scope
hi,
have you read the doc before manually upgrading?
https://doc.owncloud.com/server/9.1/admin_manual/maintenance/manual_upgrade.html
