- Upgrade Owncloud from 9.1.6 to 10.0.2
2.After running the upgrade via command line “update schema” completes “update database” completed and it stalls at "updating … I let this sit for hours with no luck?
{"reqId":"jT8ZE0MERoYPochCKMZR","level":0,"time":"2017-09-22T01:38:06+00:00","remoteAddr":"","user":"--","app":"core","method":"--","url":"--","message":"starting upgrade from 9.1.6.2 to 10.0.2.1"}
{"reqId":"jT8ZE0MERoYPochCKMZR","level":3,"time":"2017-09-22T01:38:06+00:00","remoteAddr":"","user":"--","app":"PHP","method":"--","url":"--","message":"file_put_contents(\/srv\/www\/htdocs\/owncloud\/data\/.htaccess): failed to open stream: Permission denied at \/srv\/www\/htdocs\/owncloud\/lib\/private\/Setup.php#479"}
#### Browser log
c) …
