Hi all.
I got caught by the security vulnerabilities of the past few days.
I havent updated Owncloud since installation (100% my fault) as the upgrade process has never worked for me.
The GUI version showed the following:
Current version is 10.0.8.5
Online version is 10.1.1 [stable]
Downloaded 100% (17 of 17) Downloaded 100% (17 of 17)
eDeleted 10.1.1.zip due to wrong checksume
Upgrading via cli always causes problems as PHP needs updating to a non supported! PHP version (7.4)
Now that we have had an incident and had to shut down several OwnCloud installations, We cannot upgrade them. We are getting this in the event log:
Uncaught Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: could not find driver in /var/www/html/cloud/lib/private/DB/Connection.php:62\nStack trace:\n#0 /var/www/html/cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(475): OC\DB\Connection->connect()\n#1 /var/www/html/cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(437): Doctrine\DBAL\Connection->getDatabasePlatformVersion()\n#2 /var/www/html/cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(379): Doctrine\DBAL\Connection->detectDatabasePlatform()\n#3 /var/www/html/cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(844): Doctrine\DBAL\Connection->getDatabasePlatform()\n#4 /var/www/html/cloud/lib/private/DB/Connection.php(148): Doctrine\DBAL\Connection->setTransactionIsolation()\n#5 /var/www/html/cloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(262): OC\DB\Connection->__construct()\n#6 /var/www/html/cloud/lib/private/DB/ConnectionFactory.php(139)
I Understand that this is because of a PHP issue (not being able to find the mysql driver) but I’ve now given up on it after days of trying.
The issue seems to be that Owncloud is seems to be no longer maintained, as PHP 7.4 has not been supported for over a year. Trying to get this version working seems an impossible task. And now this is being actively exploited by hackers.
Is there a simple way of migrating a failed install to nextcloud? (Just user accounts etc)
Operating system: Ubuntu 18.04, PHP 7.4 Apache
